Project Hardon
  • Thread starter Thread starter 233
  • Start date Start date
Sub £400
Quick add up
Hadron and psu £85
Mobo £40
Ram £40
CPU £50
Gpu stolen from my rig but say £120
Cooler and cables another £30
Hdd stolen from my rig but say £30 secondhand
Everything from mm apart from the pentium K which was new but their going for £35 secondhand ATM proper budget build :)
£395 all in by my maths
For that I've ended up with a 4.4ghz dual core and a 280x running at 1200/1600
Should be enough to stomp all but the most heavily threaded games but I also
Have a clear upgrade path being able to drop a quad core
CPU in with or without hyper threading later on
Can I ask at what stage does the psu fan come on?
Is it off in idle?
If so if you load prime or a furmark or a game when does the psu fan start up?
From another owner:
It ramps up noisily at boot but then turns off. It would usually stay off until you boot up a game or similar. Then it turns on fairly quickly, but it's reasonably quiet.
I respect anyone that has the patience to work in a case that small. i doubt i could even get 2 fingers inside it....
going to pull it apart again shortly to replace the mobo, one of the ram slots if fubar so a quick rebuild even more cable management
and oooh more go fast
just need to strip and recable my old phantom first, then get on to this again
From another owner:
as above system itself is whisper quiet in most circumstances, although it does spool up in gpu intensive games, obviously the gpu fans ramp up but I imagine the psu fans spool up also due to the increased load demand
