This is a project log that I probably should have made when I first started building my PC.
But oh well here we go,
I am using the Z77 chipset for this build which I hope lasts me a good 5 or so years (with a few minor changes here and the obviously) The build is primarily black and red themed (quite a lot to change for this to actually happen as you will see in the pic's below)
So the parts I currently have are:
Motherboard: Asrock extreme6
CPU: i7 3770k @ 4.5Ghz
Heatsink: Alpenfohn K2
RAM: Corsair Vengeance 16GB LP @ 1600mhz 9-9-9-24
Case: CM Storm Trooper
PSU: Corsair AX750 Proffessional
SSD: Crucial M4 128GB
GPU: GT 240 (sigh)
(Pretty much what's in my sig ahah)
So currently I am running on air but soon I will be starting my first custom loop (woohoo!) and this is what I plan to put in it (with a new GPU and monitor to go with the rest of my shiny build):
YOUR BASKET
1 x Gigabyte GeForce GTX 670 Windforce 3X 2048MB GDDR5 PCI-Express Graphics Card £266.66
1 x Benq XL2420T 24" TRUE 120Hz 3D Vision 2.0 Widescreen LED Monitor - Black/Red £249.99
1 x Koolance VID-NX680 (GeForce GTX 680) £78.32
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £70.82
1 x XSPC RX240 120mm Radiator - Black £54.98
1 x EK Dual Bay Spin Reservoir - Acetal £39.16
1 x BitFenix Recon Internet-Connected Fan Controller £24.16
1 x EK-FC680 GTX Backplate - Black £16.66
3 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £9.98 (£29.94)
1 x Dust Off Gaming Gear Compressed Air - 300ml £7.49
1 x OcUK Tube Cutter Aluminum 3-14mm £7.08
2 x Mayhems X1 UV Blood Red Coolant £6.66 (£13.32)
2 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear/UV £5.41 (£10.82)
2 x Mayhems Fine Silver Kill Coil £3.75 (£7.50)
2 x EK-PSC Adapter Rotary 90° G1/4 Black £2.99 (£5.98)
2 x EK-PSC Adapter Rotary 45° G1/4 Black £2.99 (£5.98)
6 x EK PSC Compression Fitting 7/16 (16/12mm) - G1/4 - Black £2.92 (£17.52)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.08
Total : £1,103.95 (includes shipping : £12.50).
And now for the pictures (Theres only a few right now and they aren't amazing I plan to take some more quite soon and the proposed loop made in paint)
GPU: GT 240 (sigh)
YOUR BASKET
