Project Helca Yár
Yeah. The 120 is getting moved to the back. I'll take a picture of my case this weekend when it's empty and re-plan my loop.
Nice one fella, sounds like it will be a nice short loop now you don't need all that tubing that came with the 120 in the bottom. Looking forward to seeing some pictures :D
Ouch Jeff. Casekings don't have the storm trooper windowed till 24th of august. And technics yeah lol. Still getting like 5m of tubing so if needs be I can play around as much as possible at a later date with out needing to order more. :p should get my stuff tuesday and will flush the rads on the weekend and get a dry loop made up on the saturday and possibly have it leak testing over sunday :p
Finally managed to order £500 of the £1.2k I want to spend! lol... just need to have the GPU + monitor added to the order (£10 for postage if I have to make another order... I think not!)
ahah ^.^ go for it you might inspire me :p I'll change my air coolers TIM tomorrow + draw up some loop idea's. Not sure if I want my pump in my HDD bay or on the cases floor. What do you reckon? I'm getting 4x GT's and only enough Rad room for 3x. Could try cutting a corner off and seeing if one would fit above the 8pin ATX I suppose? ;D
Ok so I've reseated my heatsink... but now my motherboard has decided to give me an error 55 on the debugger which means my memory isn't installed but it is unless I knocked it or something :/ what should I do? I can only access 2 sticks of RAM with out removing the heatsink again.
Actually now that I've found the stick of RAM at fault (definately not the DIMM slot) when I take it out I now receive error 64. Which means CPU DXE initialisation... but I have no idea what that means or how to fix it. :/
So here's a proposed loop that I have planned. ^.^ seems pretty decent to me at least.
and maybe this is why I had such bad temps after the first time I reseated the heatsink...
little overkill on the TIM that time but all sorted now :)
One small question, how do you plan to fill the loop with coolant? seems you appear to be using the only available fill port as an inlet/outlet for your loop. That the impression i get from your paint image, i apologise if i have mis-undestood it :P
