Ambitious project. Will be keeping an ete on this.
A few things to mention that might have missed you. Please don't see as criticism though, just constructive advice.
1 the yellow rectangles appear to be right where your mobo mounting lugs are. Might just be the image res and is hard to tell. they need to be out from the edge of where the bobo is.
2 the panel you are planning to remove is there to keep the heat from the psu away from the rest of your components and to provide a "nest" for your psu cables to hide in. removing it will make things esier to install (which is a rare occurance) but will lead to higher temps (in every day use).
3 Like the idea of the window. have you thought of painting the inside of the case while you're at it?
4 If you're mounting leds in the door have a think aout how you're going to connect them and where the wiring is going when the door is shut.
Good luck and Mod on
