Project: I'm Really Tight :)
hehee i paid £100 for the E8400 and the mobo and 4GB ddr2 :P on the bay as a bundle, great value! think i got a real bargain :D
lol maybe one day a might actually do a toaster build ;)
lol the seller sent the items in the toaster box because he didnt have any accessorys :D but one day maybe ill do a toaster build lol maybe when ive got 6 weeks off from school :D
sory about only just replying now, had a busy day :O
ill link someone elses toaster project later and ill tell you, its bloody TIGHT! i was supprised the fans even had room to spin when i saw it, maybe it will be a ION or fusion build as its really tight, i might do some draw ups lager if i get some time :P but watercooling might be an optio considerin ill loose allthose heatsinks....
also, zaccc, why would i lie lol? what would i gain from it :D also i didnt have to send it out of the countey as CM have a base at manchester :P
lol heres the link to the other guys taoster PC,
http://www.toasterpc.com/project_page_1.htm
ridiculous at how tight everything is!
and worryingly, ive been toaster shopping! :D argos isnt a competitior site is it? if so im sorry and ill remove the links :D found theese ;)
THIS is the cheapest, but not too sure on size,
option 2 the buttons on the from would make loverly power, reset, dvd buttons etc!
option 3 most expensive, but also the nicest looking, doesnt look much like a 'traditional' toaster though :P
lol sorry, got it built but was sooooo busy -.- but its done :P and it all works and nothings blown up (yet!)
i got bored while i was waiting for the IO Shield to come so i put some MX4 on my 4670 As it's going in another machine,
Pic0244 by bobo11223, on Flickr
Yummie!!! :)
Pic0241 by bobo11223, on Flickr
Pic0239 by bobo11223, on Flickr
Pic0238 by bobo11223, on Flickr
Pic0240 by bobo11223, on Flickr
got a nice shot of the back,
Pic0236 by bobo11223, on Flickr
all clean!
Pic0242 by bobo11223, on Flickr
wasnt sure on how much to use, but i didnt want to put too little on lol
Pic0243 by bobo11223, on Flickr
heres the case with the old stuff (the athlon 4400+ etc) which will go in another case and have the 4670 inside it,
Pic0250 by bobo11223, on Flickr
as i pulls it out, all over my hand... only been running a few months!?!?!? Me Tinkz i be having wordz with my mumzie ;)
Pic0249 by bobo11223, on Flickr
cleaned it and put it back, the inside:
Pic0251 by bobo11223, on Flickr
the beautiful:
Pic0252 by bobo11223, on Flickr
everything out, a nice case, good airflow, amazing price...
Pic0253 by bobo11223, on Flickr
mobo cpu & ram in, all was going okay so far :P
Pic0256 by bobo11223, on Flickr
maybe it would help if i put the IO Shield in first? ;)
Pic0254 by bobo11223, on Flickr
yet again, not too sure on how much to use :D heard a BB size was fine?
Pic0257 by bobo11223, on Flickr
mmmmm pretty much the extent of my photography skill in taking beauty shots :)
Pic0258 by bobo11223, on Flickr
Pic0259 by bobo11223, on Flickr
everything in and wired up, one thing that stumped me was the USB headers on the MOBO, i have 4 front pannel USB's and a Card reader, meaning 3 USB headers needed, I only found 2? lol so i only got 2 working USB's on the front pannel and my memory card ready, nothing to cry about, most of the time i dont even use 3 USB's its just a nice thing to have :P
Pic0266 by bobo11223, on Flickr
wrahhh! cable managment :)
Pic0268 by bobo11223, on Flickr
one thing that anoyyed me is when zalman made the case they made it with the pop out brackeds, annoying lol now look -.- had to take then out the old case, Do OCUK sell them?
Pic0263 by bobo11223, on Flickr
well, it started up fine!
Pic0271 by bobo11223, on Flickr
love the fact the LCD Poster is blue :)
Pic0269 by bobo11223, on Flickr
inside:
Pic0270 by bobo11223, on Flickrr
Pannel shots:
Pic0272 by bobo11223, on Flickr
Pic0273 by bobo11223, on Flickr
time for build 2! :P
first job was to fix the broken power switch -.- likkle it of swoldering :)
Pic0247 by bobo11223, on Flickr
openend the GX650, mmmm that new smell :P
Pic0276 by bobo11223, on Flickr
Pic0277 by bobo11223, on Flickr
quickly put everything in:
Pic0275 by bobo11223, on Flickr
and couldnt be bothered with cable managment ;) she's a pretty old thing ;)
Pic0278 by bobo11223, on Flickr
last thing was to unlock and overclock the 6950 :P all went okay:
6950 Overclock by bobo11223, on Flickr
Sorted! :)
Wow, looking good :) Haha, the number of times I've forgotten the IO plate :D The fan filters certainly do a good job :o What do you have your lower fan in the side panel plugged into? I plugged mine into a 12v feed and it made a horrible noise because of the mesh, I had to move it to the bottom of the case. Just wondering if you had it on a fan controller and if it made the noise any better?
thanks :D very happy with it :P the lower fan is a 3pin connection and when i looked through the mobo's manual it said each 3pin fan port ran at 100%/12v so i plugged that one amd another one into the fan headers on the mobo, i dont get any noise from it, and never have uad any noise from any fans, im going to be buying another 3 fans soon to bring it to 7 fans in the case (maximum) and ill let you know if they are okay :P
Oh right ok! I thought the fan was buggered so I unscrewed it and it was dead silent, as soon as I put it up against the mesh it makes loads of noise! :( But it's better in the bottom anyway, it has a dust filter :p
if its making a lot of noise when its put on the mesh maybe you could try putting some rubber washers on? or maybe the screws arent tight enough? lol :P
