Which SSDs are you going for? The samsung drives would match nicely and are good drives too.
Yeah it's almost ready for painting now, just got to sand it down with 800 Grit to get rid out the 120 Grit scratches.
I use some metal filler called JB Weld, its excellent stuff but the consistency is quite runny, so if you wanted to fill bigger holes then you'd have to let it cure for about 30 minutes before applying it.
Any hole bigger than about 8mm in diameter and you'll really struggle to fill it with metal filler.
A case PSU hole is far to large to fill with metal filler, grab a small sheet of aluminium and cut it to the right size, but surely your case came with a blanking plate for the psu?
  looks like I'll have that to add to my build
SSD enclosure Concept
Alright then, I don't want my SSD's hidden away and I also don't want them just placed on the floor of the case so my idea is to integrate them into the PSU cover, this way they'll be on show and the placement makes cable management a breeze.
Below is the enclosure that will be screwed into the PSU cover, it's a really simple design comprising of three pieces of acrylic.
The mounting holes in the enclosure will be tapped and the holes in the PSU cover will be countersunk to give a clean look.
I may carbon rap the SSD's so they fit in better with the colour scheme, or I may use smoked acrylic.
Are you using acrylic pipes to achieve this nice clean shape - otherwise, you may find that they sag and just look untidy.
I've looked at using solid pipes on my build as well but the problem I saw was getting everything lined up in straight lines which would mean having to find and source differant sized spacers.
Your doing a lot of work but have you considered getting a custom made power curcuit pcb to reduce cable clutter? I saw some guy xtermesystems use one to great effect on a lian li build, it looks intimadating for novices but really works well for cases which don't have kuch in the way of cable management holes.
  Back off to my own thread...
Looking good, very nice concept. I may have to borrow inspiration for a future build
Subbed
Love the idea you have with the SSD's.
Subbed!
Yeah I know that most of the tubing runs will be difficult and I am going to need a lot of angled fittings and spacers but I think the end result will be worth the effort and money, if everything was easy it would also be boring for me.
Can't say I've even heard of a custom PCB to reduce cable clutter, do you have a link?
Thanks.
Yeah - share!!!! This might be my answer!
Ooops. Apologies for the Hi-jackBack off to my own thread...
 There was a pretty serious fault in the house electrical circuit which meant getting out an electrician and also meant ripping up the floor boards to try and find the fault, expensive and time consuming.
  Nothing a drill and 2mm drill bit couldn't sort out though
 I'm pretty excited! just hope I measured everything correctly...
