Hi, and thanks to everyone who helped out until now in some other threads.
Finally, after months of keeping most of the components for this project in boxes, I found some time to think about what I am going to do, order fittings and other bits and start this project. My HW is old, so please don't laugh
But the idea for my first WC was to use whatever I had, find as much second hand WC stuff as I can and add anything else new ...So when I got the used TJ07, the guy gave me a bunch of stuff like fans, barbs, rad's, fan controller and some I intend using in this project.
Old case/starting point:
Uploaded with ImageShack.com
Have:
1* i7 920 D0
1* MB EVGA X58-SLI LE
3* Corsair 6Gb 1600Mhz CL8
1* EVGA GTX580
1* 250 Samsung 840
1* TJ 07 (in not a great state right now)
1* 650W Fractal Design Newton modular
WC:
1* 360 Rad with 1/2 thread - please identify model ?
1* Black ICE Radiator 360
1* Black ICE 240
1* Pump Laing DCC with Plexi Top
1* EK Supremacy CPU
1* Full MB MIPS POM LE for EVA X58 SLI POM LE
1* EK 580 GT Plexi
1* Memory MIPS RAM 6 POM LE
1* Temperature sensor with Display
8* Xilence Red Wing 120mm Quiet Fan
1* Sunbeamtech 6x FAN Controller
1* 100mm Reservoir 3 Holes Bottom (identify?)
Waiting on/To be ordered:
1/2 to 1/4 Thread Conversion Fitting Silver
15* 3/8"-1/2" Fittings Silver
10* 3/8"-1/2" 45 Degree Rotary Adapter Fitting Silver
2* 3/8"-1/2" 90 Degree Angle Fitting Silver
1/4" to 1/4" Thread Fitting Silver
2* Blanking Plugs for GPU Silver
1* Universal Fillport Silver
2* 8 Pin 6+2 Sleeved White Extension 300mm
1* 8 Pin 4+4 Sleeved White Extension 300mm
1* 10-13 mm Clear tubing, 2,5m
1* 10-13 mm White tubing (for the final build)
1* Silverstone SDP10 - HDD 5.25" Bay mount for 2,5" and 3,5"
1* Dual Radiator stand
1* Quad Radiator stand
1* Thermal conductive pad 1mm
50* M4 30mm - for fixing fans to rad
30* M4 5mm s- for fixing rad to stand
Loop & Placement
Project K - attaching a picture with how I want the loop to be:
Pump > Res > Mem > CPU > MB > GPU > 360 Rad > 240 Rad > Pump
Black and white theme, and I want to try later to add a custom mid-plate, maybe a cover for the 5.25 bays either alu or plexi.
Once I will have it up and running and I am happy with everything running I will uninstall it and get it sprayed/powdercoted, but first - I hope I can get it functional
1. Designing a drain/fillport - as you can see, my res has 3 holes all in the bottom. Can I drill a hole in the top cap in order to pass through a hose from the filler port which I will install on the top of the case? I am open for suggestions for better ways to do this: all I want is an easy way to do maintenance/drain/fill up! The <no name> 360 RAD has a small screw on one of the sides - is this something I can use for draining or do I need to add a tap, maybe between where the RAD's connect? Is the 5-way splitter a good idea?
2. Any clue how I can fit the WB for the memory ? I could use the mounting that came with the memory-cooler?
3. Can I use the 1mm thermal pad for the mobo WB or is there a recommended thickness?
4. What other recommendations do you have? What am I doing wrong?
Next Steps
I need to remove all the heatsinks on the mobo now and install the wb, same for CPU and memory; GPU is already done.
But the idea for my first WC was to use whatever I had, find as much second hand WC stuff as I can and add anything else new ...So when I got the used TJ07, the guy gave me a bunch of stuff like fans, barbs, rad's, fan controller and some I intend using in this project.Old case/starting point:
Uploaded with ImageShack.comHave:
1* i7 920 D0
1* EVGA GTX580
1* 250 Samsung 840
WC:
1* Black ICE 240
1* EK Supremacy CPU
1* EK 580 GT Plexi
Uploaded with ImageShack.comWaiting on/To be ordered:
Loop & Placement
Uploaded with ImageShack.com1. Designing a drain/fillport - as you can see, my res has 3 holes all in the bottom. Can I drill a hole in the top cap in order to pass through a hose from the filler port which I will install on the top of the case? I am open for suggestions for better ways to do this: all I want is an easy way to do maintenance/drain/fill up! The <no name> 360 RAD has a small screw on one of the sides - is this something I can use for draining or do I need to add a tap, maybe between where the RAD's connect? Is the 5-way splitter a good idea?
Next Steps
what a fukn noob am I ?
