This was supposed to be my post of triumph, sadly though, this isn't that post
I started work yesterday, stripping everything down, and blocking everything back up. I modded my Thermal Armour (well cut and filed great chunks out of it) and started tubing up. It was at this point I hit a few snags.
First things first though, pictures (or else you guys won't stick around lol
First thing I did was put my waterblock on the second gpu, but seeing as there are pictures of the first GPU above, I saw little point in doubling them up. Next thing was to strip the motherboard down and fit the EK true backplate:
This was pretty simple, but I noticed my EK Supreme HF didn't come with the easy mount system, so I had to use the hugely ugly screws of sheer ugliness... wait a minute!
*disappears* ............
2 minutes later ............ OK, ordered an easy mount kit!
Next I wanted to fit the Mosfet block, behold the nude MOSFETs:
With the waterblock fitted:
You may notice that the block isn't the same one I posted ages ago, this is because I changed my mind and now wanted to show off the liquid instead of hide it all in a stealthed system. Lesson learned: don't be too hasty when buying parts - it costs you more money in the long run!
Becaue I want my entire motherboard watercooled I need to fit a Southbridge block, for this I fitted my EK one (sorry no pics of the naked P67, I wanted to preserve its modesty [actually I forgot to take a picture, I was too busy laughing at is pea sized figure that was attached to a heat sink many many times bigger than it is])
You may notice that I didn't use my black top SB block, so I now have a spare Sabertooth P67 MOSFET and a spare P67 compatible chipset waterblock.
I then placed the Indigo Extreme on the CPU and followed it with the waterblock. Sorry about the lack of pictures, applying the Indigo Extreme required too much concentration I clean forgot to take pictures.
But you can just about see an edge of it there!
With that, my motherboard is all blocked up, as the below picture shows:
The chipset block is slightly skewed, because thats the only way it fits in!
I knew that the Thermal Armour was not going to fit anymore, but I bought this motherboard for its looks... so I can't let that go. The armour must fit no matter what so 5 year VIP warranty be damned, I'm cutting it up!
The below pictures show the extent of the water block conflicts:
Thats a lot of cutting! I was so focused on cutting into it without the right tools and without damaging the areas of the armour I wanted to keep that I took no pictures during this time. Helpful hint: do not cut away at the plastic with tin snips and wire cutters and expect to get a nice clean edge. I ended up having to run out and buy a couple of hand files to get some cleaner edges. Sorry for the lack of pictures :/
I was then ready to start tubing bits up, so I took the fittings picture I promised you guys ages ago:
Included in that picture is:
32 1/2-3/4" XSPC Compressions
8 Bitspower black sparkle 90 degree rotaries
7 Bitspower black sparkle 45 degree rotaries
2 Bitspower black sparkle T Blocks
2 Bitspower black sparkle plugs
2 Koolance RAM-35 Type 2 fittings
The following picture shows what the motherboard tray looks like in its present state:
I had originally planned to have the SB block inlet be a 45degree fitting, however when I tried that the tube ended up resting against the parallel flow crossfire tubing, which I really didn't like. So I took one of the 90 degree pieces and tried that instead, now the tube runs directly up between the crossfire tubing and bridge, touching nothing - which to me looks better. Unfortunately this move was the cause of my first (and worst) snag. More on that later. You may also notice that the CPU outlet and MOSFET inlet are not aligned - this is my second snag.
I decided to tube up the main loop's reservoir while I stewed over my now imminent delays.
and then I connected the GPU loop's reservoir to its pump inlet. This tube had to be longer, and doesn't look as good as the other tubing, but nothing I can do about that.
Unfortunately this is all I could do as I no longer have enough 90 degree pieces to tube up the GPU reservoir. Here is what all the reservoir tubing looks like in its current state:
I was quite disheartened by now, as I really wanted to finish it all up. But there is a silver lining to these delays.
During the air testing, I began noticing my PSU (Antec TPQ-1000) has developed a weird fan noise, which is generally irritating to me when not wearing my headphones (or getting drowned out by the angry vacuum cleaners formally known as 6970 stock coolers), so I ordered a new 80mm fan to replace it with. If I had tubed everything up I would have to drain at least the GPU loop to be able to remove the PSU to do this maintenance.
I measured the misalignment of the CPU outlet and MOSFET inlet to be 9mm, thats an odd number, so I ordered a 10mm extender - it should be possible to compensate for the 1mm difference with the tubing. I did try to order my last 90 degree fitting, but its out of stock everywhere, and the ETA for it to be back in stock is 7-10 days
I guess I will use that time to fix the PSU, change the CPU block mounting mechanism and do all the cable management...
*sigh*
