- 29 Jun 2016
Yes capacity will affect performance. 4gb of ram simply isn't enough any more.
This design is looking crazy good mate, if it turns out anything like the renders its going to be superb! The idea of having that back radiator rack is something i've often thought should be a feature in some cube cases.
Subbed!
Can't beat a properly bonkers project, will definitely be following this one!
Top work on the renders as well, that's a mad amount of work for idea's / planning stage mock-ups![]()
If you can match those renders this will be something special.
Fingers crossed, your planning seems top notch
Having owned a TJ07, i'll be interested in how you plan to fabricate the front ( where the drive bays and that switch panel is ), to mask that off.
The hex cutting is going to require some precision.
