- 17 Oct 2012
- Fortunately Mars
So, its all complete
after less then 5 weeks, 3 weeks of planning and a lot of research, the build is complete!
I will start off with the build, then the completed system in place on the desk
Smashed the tubing out, i dont know if its just luck but every piece came out really well, i didnt use a former or any bending devices, just the rubber insert, a heatgun and some mental angles, the best part is however that i designed all of the bends previous with...... wait for it...... LEGO!! it worked prefectly, as you will see
That flashback
All piping complete
Leak testing for 7 hours
In position and ready to start
ITS ALIVE
Straight into the automatic crazy overclock profile
Impressive
but i will stick with 4.3Ghz now
Current Idle temps are 21.C
Under load (Prime95) 39.C - 42.C at 4.3Ghz
Very impressive
Thanks for reading
(32GB ram will be arriving on the 24 - 28th this month)
after less then 5 weeks, 3 weeks of planning and a lot of research, the build is complete!I will start off with the build, then the completed system in place on the desk
That flashback
All piping complete
ITS ALIVE
Impressive
Very impressive
Thanks for reading
