Project : LV-426 an Alien inspired build ( a Jonsbo MOD5 build )
More cable management, almost done with the cabling now. And fitted the mini-screen ( need to finish the bezel for it ).
Question @Brizzles - those black plastic clips holding the fan cables, they come with the case or did you source them separately? I’m already gonna be ordering some of those spark plug clips as they look bloody good but some of those black clips and a drill bit would tidy my own boring rig up no end.
Amazon - dirt cheap adhesive foam pad backed
Update.
Had to replace the EK AIO due to a noisey pump, so most of my cable routing had to be stripped out and will need redoing again.
Gave me time to finish the mini-screen ( bezel needs finishing still ) but all the AIDA64 side and my design is done ( until i change it for the 6th time! ).
Started sorting/testing the RGB, so this is how it looks atm.
Getting there :)
Couple more pics.
Switched the AIO to 'pipes at top' as it was very tight and would be a complete pain to swap out graphics cards.
Vertical GPU bracket installed and tubing re-done.
Now the main hardware is positioned how i want it, i can move on to cable tidying the back again.
Still some 'things' to add to give it a futuristicy look, so not done yet :D
SPEC :
CASE : Jonsbo MOD 5
CPU : AMD Ryzen 7 7800X3D Eight Core 5.00GHz
GPU : Asus GeForce RTX 4070 Dual 12GB
MOBO : Asus ROG Strix B650E-E Gaming WIFI
RAM : Corsair Dominator Platinum Black 32GB (2X16GB) DDR5 6000MHz C30
PSU : Seasonic Prime PX-850 850W 80 Plus Platinum Modular
SSD : 2 x 1TB WD Black SN850X NVME PCI-E Gen4 / 1 x 2TB WD Black SN770 NVME PCI-E Gen4
COOLING : Arctic Liquid Freezer II A-RGB - 360mm AIO
FANS : 12 x Arctic P12 Static Pressure 120mm PWM PST A-RGB 0dB Fan
CableMod Vertical PCI-e Bracket PCI-e 4.0 Edition
CableMod Classic ModMesh RT-Series Cable Kit - Carbon
Phanteks Halo fan surrounds
Elecrow 5" HDMI Monitor
Another small update.
Managed to squeeze in a new gfx card - Gainward Phoenix RTX 4080
a lot of the rear cabling is sorted, but i wanted to make a 'feature' of it to keep up a futuristic/machiney type theme, so started work on some graphics i had printed.
Going to try and make ' metal plaque effect ' pieces for various places on the build.
More to come
Thanks all.
Bit more to add, started on the cabling at the back. I could have hid it away, but that would have been too easy- so i decided to make it a part of the build in a machiney type way. And nothing says machiney more than CONDUIT !!!!! ( well there are probably better examples )
Looks OK i think ( i hope ) needs a little tidying.
Ran out of conduit at this point, so need to order some more.
And remember, a tidy workplace is a safe workpl.................Forget it.
Thanks for popping in.
