Well I have started to put together my PC with a full water setup for cooling.
I am using mostly my rig in my sig but updating the GPU
So I should start with a list of components
PC consists of
MSI GD80 Motherboard
i5 750 CPU
4GB of Corsair xms3
Corsair Force series SSD 60GB
500GB hdd (this might have to go if I cannot fit it in, bring on the 500GB ssd's for £90,,,,,one day)
Corsair TX 650w PSU
Asus GTX480 courtesy of OcUK (well I bought it from there,in the post)
Asus D1 Sound card
1 DVD-rw
Case, Lian-Li PC50b Armoursuit
6 120mm fans, 2 140mm fans all xigmatek orange blades and white led
Lamptron FC2 fan controller (still to buy)
Cable brading of main wires in the case will be done or I get the ready made versions, not too sure which is most cost effective yet.
Well thats mainly the pc sorted, now onto what has got to be fitted in my Lian-Li pc50b armoursuit, not the biggest of cases with it being a mid tower and have had to do a little dremeling in place's
Window side panel comming soon
Lighting is coming from the fans, a set of 4 sharkoon UV 12 inch tubes and thats about it really
The water cooling I picked consists of
1 EK XT 240mm Radiator plus 4 120mm fans
1 EK XT 120mm Radiator plus 2 120mm fans
1 EK Supreme HF Plexi copper CPU block
1 EK GTX480 plexi copper block (in the post)
1 EK DDC X-Res 140
1 Laing DDC 1T pump (Unsure if this will be enough maybe someone in the know could advise
1 Pump mounting plate thingy
12 Bitspower G1/4" Matt Black 1/2" Fitting - BP-MBWP-C01 so far
they are so epensive and it's looking like I need a couple of the real expensive triple rotary fittings, unsure yet though
Muskaleer 7/16" Tubing UV Orange
, was unsure what colour but I think blue has been done a lot so thought would make a change and went with orange, I have xigmatek orange fans so it should go nice
1 Fillport (unsure wether to use it though)
Here are some pics
of my progress, I think maybe another 1-2 weeks and it will be done, and like I say all this is going into my pc50b Armoursuit,somehow
(maybe it will fit no problem but all ready I am not sure where my 500gb hdd is going to go)
Also this is my first try at water cooling my rig
enjoy and do say if I have done something completly noob
PC consists of
i5 750 CPU
4GB of Corsair xms3
Corsair TX 650w PSU
Asus D1 Sound card
1 DVD-rw
1 EK DDC X-Res 140
)1 Pump mounting plate thingy
they are so epensive and it's looking like I need a couple of the real expensive triple rotary fittings, unsure yet thoughMuskaleer 7/16" Tubing UV Orange
Here are some pics
(maybe it will fit no problem but all ready I am not sure where my 500gb hdd is going to go)Also this is my first try at water cooling my rig
