Project, make it fit.
Just a dremel to cut it out, bit of a pain and caught the case in a couple of places but it's not really noticeable, used some rubber u channel for trim and then stuck the window on with some double sided foam tape, it's a bit of a tight fit getting it back on, I left some double sided tape exposed at the back edge and think it sticks to the case when putting it on, will sort it out when I next take it off.
nice build there hyperst.
really like the loop layout and colour scheme you have gone for :)
great cable management too
well it was a bit of a mismatch on the orange, in the end i didn't really like it with the blue of the motherboard lights so decided on a complete change of colour and went with white to go with the fractal case, cables I did myself.
now up and running, only an hour or so to leak test as these compression fittings are real tight so I have faith in them
the white looks bloody awesome and much better than the previous colour scheme! good choice and well executed.
Bit of an update, have now got a few new part, namely an Asus Z77 motherboard and 2500k cpu, changed to clear pipes and blood red coolant.
Some pictures
Thinking of updating the fans to some red led ones and maybe a new pump in the near future, missing all the bling of led fans lately:D
I was very interested in reading your first build from 2011 (see my thread project Galileo) as my case is pretty much the same as yours and i'm going to using almost the same sort of placements. Since yours is so good though I'm going to step have to step up my game and put a window in the side or do somthing different.
Yeah I need to do my window:D, few more things to do as well, but it cost money which i'm short of:(, wanting a PSU, pump, new cable's, new fans, lighting the list goes on and on, oh and also a side window in the panel with a grill for the bottom fans, I don't think I've seen yours, I'll take a look for it now.
