- 20 Nov 2009
hi there,
for a while i had been thinking about building my own PC and had been hovering around the forum and thinking how much fun/interesting it was.
so there i am...thinking, I'm going to do it !
so i looked around my room and gathered up loads of rc stuff from when i used to race them and counted up how much i could get for them, and believe it or not not was quite a lot and nearly enough to buy stuff for my new build.
so i started looking at what i could get with this new found money,
as most of you probably know, you aim high
so i thought about the cm932 or cm690 II but the budget when further looked at could not be stretched that far
.....so i thought, why not a cheaper case, because for my first build i wouldn't really need that much space etc.
One case stood out at me, well built, modern, efficient, good reviews...
many may think its not up to much but i went for the ANTEC 300 !
I then found one for a bit less than new but in new condition,
when it arrived i was very impressed
it wasn't bad at all, it was very nice.
Being a bit of a dab hand at engineering and manufacturing i thought that it was a case with a lot of potential.......that's when the drill and grinder came out !!
so first i had to take it apart+take out front panel connectors etc and drill out ALL rivet ( there is a lot i can tell you!)
then i cut out the grills on the front fan holders as they don't seem to have any real purpose and they will just slow air flow.
used the die grinder on those little bits because the angle grinder discs are far to big to get into all of those small places
then its onto the main case mods
i saw that people were moaning about the cable management in this case so i thought i would do something about it
i used the abrasive ends for the die grinder for the circular bits and angle grinder for the straight bits. (sorry for the quality, i took it on my phone (2mp)
As i was looking at all of these more expensive cases i really liked the window idea, so therefor...i had to make my own
the final pics of that and the acrylic later
more later when i put them on the computer of the painted bits
