Project: Midnight Blue
ive tried it with compressed air and i think it might just be dust thats hardend on,
thanks for all the comments though lads, ill be starting the w/c soon, just need to order a few bits first :)
James
thanks a lot :) had to do something a tad more ambition than buying a big case, spray the outside and watercooling it didnt i :D
i will order the last few bits soon btw, just havent had time recently
Tis nice! I've had a big mod planned for my 300 for months now, but I'm having hardware troubles that I want to get solved first. :(
Very nice, I am also a fanboy of the 300 case and I like your cable routing holes, is there much room behind the mobo tray of the side panel however? It's also a shame you didn't cut a cpu hatch as well whilst you was at it, would make changing the block at a later date if needed a lot easier.
