Project MSI Osiris
Ahh ok, I see what you mean now.
100hz makes all the difference trust me! Going hard-line as well now :).
Those temps seem perfect as well. There's nothing like a water cooled system :).
yea im expecting it to jump a lot when i end up adding 1.29-1.35 volts , i do have a good chip though as it was in my Alienware anf got .cant get how cold the rads are and the single card . need to take apart the second VGA power cable as needs to be the red black red , and not the red black red back it came as and put in the comb . got a spare pair of hands coming shortly to help with the desk . yea go for it , the amount of stuff i still got is insane , i ordered 20 hardline fittings for the hardline tubing and only used 10 lol . need to sell them now as cant send them back as had them for too long .
How do i get a mod to change the heading of the thread to the new name of the project build ?
I added some more distilled water along with the EK concentrate and then added some mayhem's blood red dye and its very bloody red now . wont post any more pics now until its completely done and hopefull the new monitor comes before the weekend .
I meant the X34s 100hz (as well as g-sync and IPS) :P vs your 4k 60hz. CPU should do 4.5 at around 1.3v and 4.7 around 1.35v. That's the average figure for the chips anyway.
Sounds great, no doubt this desk is going to be a monster as well :). Look forward to it.
Hahah my bad about the misunderstanding on the 100hz ..I actually got 75hz overclock on the philips with mini display to graphics card but it had no gysync and I do get stutter on the philips now and again . Lol about the 100hz a haha that's tiredness for you looking after 2 kids and trying to do a million things at once lol .. but I'm not far wrong though temps will climb a bit on every 100hz on the cpu as it's not just 100hz it's 800hz with 8 cores ..glad I influenced you on going hardline ..I will unveil with maybe a video of the pc but want to make a video without uploading to YouTube .
Thanks man , my misses named it , she just googled godlike and came up with a few names then went on wiki and seen this Godlike named Osiris and then i read it and said yea man its perfect name due to the death and Resurrection as its taken over 2 months for this beast to come alive . its going to be sexy sexy sexy .. ,and just waiting on L shaped Led connectors so i can put some LED strips in the front bezel .Thinking the Blood theme is a bit to dark now , might have to take some out and give it some aspirin to thin the blood (cooling fluid) out .
Delayed due to monitor coming tomorrow and trying to get the LED strips controlled by the farbwerk and destroyed 2 connector cables trying to poke it through holes. so ordered another from OC . will just have the 2 strips for now until other cable arrives. getting the GPU power leads inline was a pain. all i have to do now is tidy and put on the grills ,and a little more cable tidy at the rear . tested on gaming at 4K on Project cars and getting a solid 80fps on max settings .
Temps
GPU Idle with both cards connecting 24c
GPU on full load on standard OC at 1329mhz boost 45c and 43c
CPU Idle at 1500mhz 29c
CPU on 4ghz 47c
pump is on 50% and around 3200rpm
all 8 fans 2 x 4 are on 60% 900rpm
not to bad i must say and plenty of room to overclock .
Pics to arrive when i have set it all up with new X34 tomorrow if i dont get to carried away /
computer is finished been playing around with it , only problems i have at the moment is that the overclock at 4ghz keeps resetting now and again for no reason . i have 3000mhz ram thats causing the issue . as i have XMP profile on the BLK is at 125 so if its 3.2ghz in the command center its really 4ghz . if i change the 125 base cllock in the bios my ram then goes to 2400mhz .for some reason if i dont have it on defualt clock in bios when XMP is on the CPU in bios goes to 3.4ghz and when it boots is shuts down and then tried to come back on and keeps shutting down , i think the 3.5ghz in bios then gets transferred to the command center when booting and then uses the 125BLK and then crashes as its not going to boot on 3.5ghz x125 . need to figure it all out , either that i have faulty ram .
Oh i bought the X34 acer and its going back due to very bad backlight bleed . back on 4k monitor and now i hate None Gsysnc .playing games on 40in 4k screen now is none playable lol .
Haha knew the G-sync would get you :). Sucks about the backlight bleed, they look like great monitors but like the swift its finding the right one. Haven't opened my swift up yet due to the hard-line.
Finished my hard-line yesterday, looks soo much better than flexible but boy it was hard work :p . I also had to nick a bend idea or two as I just couldn't get it to go any other way.
Are you getting another X34 or another monitor? I leave my memory out of XMP but just ensure memory voltage is the same as on the stick as mine had loads of problems on stock. Other than that update to latest bios etc.
Keep us updated, can't wait to see a finished video.
The G-sync has proper blown me away , I wouldn't mind just asking OC to just replace the screen for the same , going from a 40in then to a 34 ultra wide on the height side of things is a step down , but when i packed away the acer and hooked up my Philips i could instantly tell the difference in fast moving games like project cars , project cars was just such a pleasure to play using the Acer . was very immersive , but still lacked the size of things . im now wanting the 32in 4K Acer thats availbale for pre order which is also Gsync and thats also IPS .
Would love to know what the ROG is like , i just sold my 27in Asus PB278q IPS to a friend , best monitor i ever had and had it clocked at 85hz with no problems , might ask for it back lol and then just get a Dell Gsync to go beside it as could be waiting a while for the Acer as there is no release date and details are very limited .
Will do a nice set og photos of the build . just need to do my homework on overclocking the beast as it has the double pins to overclock it better .i can get 4.375ghz stable with xmp ..might just turn on overclock genie see what that comes up with but read stories that it down clocks the ram to 2666mhz on 3000 mhz ram strange as this ram is made for this board as there is MSI dragon series of the same RAM somewhere .
do a refresh of your build would love to see your work , all my mates love my pc on how quiet it is ..it really is silent missis is happy and bedroom is not a sauna lol .
You can see the updated build in my sig tomorrow :) when i can get a decent photo, looks far better than flexi which clouded up and looked very pink. This is a lovely cherry red. Just waiting to finish the ssd/HDD plate with some type of wrap carbon or some type of brushed steel and get rid of the bolt heads.
Its a big difference with G-sync :). The x34 tempted me but I went for the new swift IPS 165hz. Super smooth, I love high refresh rates and 100 is about my limit for fps shooters as I'm very sensitive.
That Acer sounds great aswell, about perfect size I think. 4k coupled with the g-sync aswell will be extremely nice indeed.
You can see the updated build in my SIG tomorrow :), looks far better than flexi which clouded up and looked very pink. This is a lovely cherry red. Just waiting to finish the ssd/HDD plate with some type of wrap carbon or some type of brushed steel and get rid of the bolt heads.
Its a big difference with G-sync :). The x34 tempted me but I went for the new swift IPS 165hz. Super smooth, I love high refresh rates and 100 is about my limit for fps shooters as I'm very sensitive. There is a touch of glow/blb in the top right but nothing worth returning it for.
I was super surprised how cooler my room is aswell, those reference GPU coolers were ridiculous. The amount of heat and noise, they were like jet engines.
your sig not working .
Might do what i was going to do in the first place and get the ROG IPS. can always send it back if i get a dud . but then im always going to pine for bigger screen (Acer 32 4K G-sync ), 4K never going to get 100fps on most new games nowadays anyway and not sure but the other day while using the Acer you dont have to have vsync on to activate gsync as it was buttery smooth getting 140+ fps on project cars on full wack. even had AA on full . but it was even better when vsync was on then it capped the screen at 100fps ..so smooth . and reading reviews i wont notice the difference between 60 and 100 frames when G-sync is on as its smooth any way .
will update the thread tomorrow with pics , not sure about a video as not really interested in uploading to you tube .
I was going to do a video once the whole gaming set up was complete , I.E G920 wheel , K95 keyboard, M65 Mouse which all i got for Xmas off my missis . she knows i know about the wheel lol as i signed for it lol along with the gear shfter .
I even Considered getting 3x ROG TN panels
Just letting people know the pc is finished but having so much fun on it at the moment and just waiting until its complete with its perfect brother (Monitor with G-sync) .
It needs a bit of a tidy up with the cables and the desl lol , planning on using the spare XXXL mats i got for a splash back , in 2 weeks i will have have a new Keyboard , mouse , and wheel set up and a new Monitor/s and maybe a gaming chair .
pics dont do this justice as when the Lights are on the motherbaord it looks fantastic , i had to order a new LED controller for the stripps as i burnt out the one i had as i think i wired up the LEDS wrong so waiting for the Bluetooth Aqua computers Fabwerk Colour . , the pc will then come alive with white LEDS in side the sides as it compliments the RED BLood .
