Project: Plasma Cannon
holy ****! Ludicrous build!! I vote plate 1, then 2. Not a fan of 3.
Seriously nice work; what are you going to do with it once it's done?
Cheers guys looks like most like number 2 followed by Number 1 , so heres some images of the plates in place. I havent attached them yet so there only placed on hense why there not flush with the case.
Plate number 1
Plate number 2
Edit: I forgot to ask how heavy is it?
Im not saying till the guess the weight compition is finished ;) some prizes have allready been picked out so stay tuned.
And thanks for keep comming back to this thread guys just gone passed 50,000 views!
Every time I come back to this thread there is some new to be amazed by. A build of epic proportions and a true display of skills and determination in getting it built. Well done sir, well done.
definitely plate 2 imho, plate 1 is a bit.....meh and a motto on that build just isnt worth it
This is absolutely crazy. I don't know what more to say than that other than I'm extremely jealous of both your skills and this build!
I like plate 2, the minimalist approach has always appealed to me. I am amazed by the craftsmanship on this build, three cheers for you good sir.
Sweet Jesus, shock and awe this thing is just wow absolutely incredible, etc etc beyond impressive just awesome
this build is insane!
I literally wouldn't even know where to start if I had to do something similar.
well done
Amazing work as always, one of the first project logs I check when visiting OCUK. Crazy build and worthy of all the attention received.
Surely this should warrant some awards from the hardcore modding scene?
(Oh, plate 2 - much more classy for your build!)
Sponsored by
Thanks for all the kind replys!
Small update before I do the final build post.
As the Stand was Steel I needed some protection from it corroding so a simple can of paint did the trick. the ends then protected with some small plastic caps.
As requested Plate 2 was the winner so that was next task was to securely fix it to the drive tray. To do this I unclipped the original plastic tray and milled the face of it to get a flat surface.
Then was a simple task of sticking the brass plate to the milled face.
very short post but the next one will make up for it. Final Photos are ready to be uploaded just need to finish up last of the videos.
The amount of work,effort & skill put in to this build is outstanding
most definitely the best build/log i'v ever seen & most likely the best I will ever see :D
