- 17 Oct 2012
- unfortunately Mars
Hey there peeps, so i have just finished building my new gaming rig, i made another thread on it - "Clicky Clicky"
Well, now that i have the system up and running with out any problems, im finally going water cooled, i have spent a crazy amount of time researching what to use, where to get it from etc......, i have chosen to go the EK route due to the fact that they look like they have the best products, here is the list of things that i am going to be using:
First off is the Pump and the reservoir, i have choosen to go for a 2.2 combo:
I will also be using a EK plate to keep these together:
Next is the CPU block that i will be using, its the HF waterblock for the 1155 socket:
Next is the radiators that i am going to be using, i will be using one EK coolstream 120mm radiator and also one EK coolstream 240mm radiator:
I will be using EK barb fittings, i might change over to EK compression fittings, but for now i want to get the system up and running:
I already had some blue tubing that was given to me by a freind not to long ago so i will be using that until i want to change it, i still really want to keep my word about the black and white theme, but for now im in the testing phase:
Finally, i wanted to get some black fans to go with the EK radiator that would look good, so i got two EK 120mm fans:
i also have some anti - kink wire, but i dont know if im going to use it yet:
Thats all until i have some spair time on my hands
cheers folks!
cheers folks!
