Project Radster - Case Labs S8
I think we may have a few people who actually said they have CL case.
I know someone had a project log with STH10. Think it was called 'Project Bloodfang', but didn't see any updates for a while.
Looks like I may need to change the list of things to buy, a little.
I will be playing ESO with some friends and looks like I have strongest PC, means I'll be frapsing a lot. I tried it a bit this week and the amount of space it takes is huge.
So plan for March is bigger storage :D
Probably 2 3TB caviar green's, I think I can run them in raid as well.
And my mobo have mSATA port, so I'd add the ssd there to run OS.
And I already spoke with davido_labido about the cable sleeving so that will eat up most of my money in March.
/goes to FedEx page and spams refresh on tracking page
There was pre-order bonus, -40$, so including delivery 540$, thats 350£.
But mine have some bonus options.
The most basic one would cost you around 460$, including delivery, but that's without front rad mount, side rad mount, windows or custom color or accessories, like mounting system for 5.25" devices.
Its best to check at their site:
http://www.caselabs-store.com
I am not sure yet, whether I am going to bend it or use angled connections.
First would be cheaper, but I feel a bit uneasy/unsure if they are going to be solid enough to withstand the water pressure.
I really wouldn't want to have a leak over 2k£ worth of components /touch wood
Have not done the bending on this tubing myself, but if you look online think you will find that many have done it ok, with no problems. Some are running two D5 pumps in serial so, you should be ok.
I understand your trepidation though - a potential big loss if it fails and water everywhere, but to be honest that is always a risk with any type of watercooling, but if done correctly - should be ok.
Good luck
Mark
Ps Looks like Monday for the case delivery then?????
It looks like Monday, I think :)
Last update on tracking was yesterday 9pm in Indianapolis, which is 2/3 way across the States. By now it should be already on the plane to UK. Or so I hope.
Seen it ages ago, but I don't think I'll buy it.
Its 50£ I can spend on something else. Another hdd for example.
Or Edifier speakers. There are other ways to make angles :D Beer bottle comes to mind.
This won't do.
I am polish, you wouldn't notice I was drinking until I reach my 3rd or 4th 4 pack of guiness :D
16 bottles won't fit inside S8.
My case is going by some weird route.
It was going straight from western coast to eastern coast and then turned south, wtf.
MEXICO?????
MEXICO?????
My sth10 went the same way.mind you,i had it custom painted and it took them 6 days to get the case to me,i was amazed how quick they got it painted and shipped to the uk in 6 days.
