Update 30/10/2012 - Water Loop Finished
I've had a little time the past few days to get on with this build and at last the water loop is complete. The thing is there are so many joins in this loop I thought I'd better take some photos and get this update posted before I fill it with water
This is the view in the top bay with the front off:
The T piece coming from the top of the rad is a bleed port to make filling and draining easier. This sits nicely on the top next to the fill port:
coming down from the T is the return pipe back to the res:
The res is an Alphacool and below is a Lamptron FC6 fan controller. Below the FC6 and barely visible in this pic are the backs of the two LCD temperature displays, one showing the air temp and the other the water.
The pipe on the left leads down to the pump in the bottom of the case:
The pump is hardly visible in the pic, the two fittings in the middle are the inlet and outlet though. From the pump the loop attaches to the bottom rad then out the top and into another T fitting. The right side of this fitting houses the water temperature sensor, the other outlet to the bottom of the motherboard. There is also a drain port at the bottom.
The loop starts in the bottom right of the picture going to the first motherboard block, then to the CPU, then the second M/B block and finally the GPU's. I originally had the GPU's in serial but swapped it over to parallel to make the loop a little less restrictive. Actually I just preferred the look of it this way.
The loop then leaves the GPU's and travels into the top chamber and back to the rad.
That's it for now - time to fill it up
