Very nice build.
Whats the model of that high speed cutter thingy you used to drill holes in case?
Diameter was really small and I need a tool like that a lot.
Cheers
Me?
Its ok matey, keep hold of it or pass it on to someone who needs it
Tried claiming from contents insurance on the damaged parts?
Yep
I'll pass the charity on when I come to sell my Mountain Mod's case on here, I'm sure someone will be happy for it. Unfortunately, and rather stupidly, I don't have contents insurance. Guess who is kicking themselves now huh![]()
I mounted my res on a 240mm rad in the drive bays. I wasn't crazy enough to try mounting anything externally. She's already a beast ;oWhich Rad is it? Just out of curiosity.
Nice to see another Cosmos SI mounted my res on a 240mm rad in the drive bays. I wasn't crazy enough to try mounting anything externally. She's already a beast ;o
So, I gave the rig a test today and it would seem the mainboard (at the least) is dead. I tested with the following configs and always got the same result, being a brief (2ms or so) burst of life and then nothing with exception to the final config in which I get nothing at all; I'm unsure if this is by design of the board or the symptom of a deeper issue as most boards I have had in the past will still power on but throw a "beep" code when there is no CPU and/or RAM installed.
- MB, CPU, 10GB RAM, 2x 7970's
- MB, CPU, 2GB (single stick) RAM, 2x 7970's
- MB, CPU, no RAM, 2x 7970's
- MB, no CPU, no RAM, 2x 7970's
As mentioned the first three show some sign of life, albeit for an extremely short period of time; IE enough to allow the pump to move water approx 1CM through the loop. The final config does nothing to show any signs of life other that the usual LED's which are lit when there is power to the main board. I will test the 7970's in my current working rig tomorrow to see if they still work, failing that it's a good chance to add the second 5970 I have lying around![]()
I'm hoping to get a few spare hours today to put the GPU's into my current rig and give them a quick test. Does anyone know if it's okay to run them water free for even a couple of minutes?
. Well I'm typing this in safe mode right now seen as Windows is throwing a 0x101 error at me. Any ideas on that one?So I decided just to go full hog and install the cards properly, and if they didn't work I was going to throw the whole lot out my window, pile it up, and burn the lot of it.
Turns out they still work. Well I'm typing this in safe mode right now seen as Windows is throwing a 0x101 error at me. Any ideas on that one?
Have any parts been destroyed, in testing so far?
) and the BSOD has gone away, I still need to reboot to finish driver installation but it's looking good up to now.Ive picked up a fully loaded cosmos S with water cooling, nearly broke my back.
So i can only imagine with all those radiators on the side would be instant spine destruction.
maybe i should lift with my legs....
