Hope you're starting to feel better Andy.
Ok, Black Friday just got mentioned and so I felt obliged to give OCUK a chunk of money
I'm just not sure the MSI board would fit - the extra PCIE power connector at the bottom might interfere with a glass tubing run or the heatsink on the 10Gb NIC. The 870E allows me to put the NIC in either slot too so gives me a bit of flexibility.
Order Gigabyte X870 Aorus Elite WIFI7 (Socket AM5) DDR5 ATX Motherboard now online and benefit from fast delivery.
www.overclockers.co.uk
Order Corsair Vengeance 32GB EXPO (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel now online and benefit from fast delivery.
Looked at the ROG Strix 1200W as it was on discount. Only problem is that it's 30mm longer and that would mean moving the flow sensor back and then rearranging filter and fittings to compensate....so I went with an easy life! Quiet was a fair priority as my existing PSU is silent...until you game and the fan cranks up.
Order Silverstone HELA 850R 80 Plus Platinum PCIe 5.0 Modular Power Supply now online and benefit from fast delivery.
Order Asus GeForce RTX 4080 SUPER TUF OC 16GB GDDR6X PCI-Express Graphics Card now online and benefit from fast delivery.
The Strix/TUF version of this
Order Alphacool Eisblock Aurora Acryl GPX-N RTX 4080 Reference with Backplate Water Block now online and benefit from fast delivery.
Order Crucial T700 2TB NVMe PCIe Gen5 M.2 Solid State Drive (CT2000T700SSD3) now online and benefit from fast delivery.
Order Thermal Grizzly Kryonaut High Performance Thermal Paste - 11.1g / 3 ml now online and benefit from fast delivery.
The clear (non-UV) version of this - enough to fill and some spare for when I inevitably wash the carpet at some point...again
Order XSPC EC6 Coolant Clear UV 1L now online and benefit from fast delivery.
I
think the existing CPU block will fit as it seems to be AM3 / AM3+ / AM4 / TR4 and is almost identical to the one I was looking at. Worst case, the newer Bykski block is £60-odd plus shipping. I like the EK Quantum...but it's nearly four times the price
So, that just leaves me needing a CPU and as you can tell, I'm fairly commited to a 9800X3D.
@ALXAndy I totally hear (and agree with) you on the i9...but I've just lost interest in the Intel option and going back three generations seems like too much of a compromise - even though you're right and it would work just fine. I need a GPU, PCIE3x4 for NIC and M.2 SSD (either Gen5 or 2xGen4) and it's actually quite difficult to get that all in. Definitely an advantage the Threadripper has there with 48 lanes of stick-what-you-want-in!
