Cheers. I've checked and it's currently limited and correctly set...but it still merrily plots moves beyond range. Trying to do a 2D Pocket instead of a faceing, it also plunges the whole tool and shaft through the stock and the bed...which is helpful. If you simulate with machine, it does at least spot there is overtravel and collision. I might need to reconfigure the Z axis limits as currently they're -30odd to +30odd which if I remember matches what the machine spits out but might not be helpful for programming.
