Some small updates, so the giant was drained and removed the CPU block firstly to redo my delid to be 100% confident it was awesome. Its now awesome and the good news is that second time round I didnt kill it either... After that the front fans were swapped out with this swag:
The result is a much less whiney fan noise and consistent RPM from all the 3 hubs including the front 8 fan stack. Pretty happy with that, if you are viewing this with binoculars you will have seen the yellow/green UV coolant - WTF you say?! Short story, the dye does nothing on the blood red coolant so having drained out roughly 2 litres of prime red I literally threw it away after its two day stint and added two litres of this.
Result was an interesting deep orange with the odd strange tint. Much better:
Been pretty busy really and away, ironically after all this the only thing broken is my mouse... So a new Deathadder Chroma turned up today, plus I had a bit of a crack overclocking the GPUs:
With the fans at 50%, pumps are silent at 65% (Pumps are working fine off the mobo header for signal connected with a Y splitter from EK) it still only hit 38/39c with a reasonable boost going on. CPU next but for whatever reason my 6700k which had run fine at 4.8 is being a pain so work required to shift it past the happy 4.5.
