Project Smurf 3.0
Love these cases. I just redid the loop in mine the other day, I'm keen to see how you do your tubing on this one. You've got some great kit going into yours.
Yeah the tubing is taking some thought I can tell you, mainly just waiting on the GPU blocks and I think... Hope... The backplates are good for early next week. So far i'm a pump short, potentially, so planning around that and will probably just use clear distilled and drain to fill once everything is ready.
Mainly excited to get the GPUs clocked under water, the CPU seems to be pretty nice since I did my delid so should be good! Mainly I like the space in it, its so crammed right now its nice to get some space and fit it in right. Case looks great but they have kinda stopped replying about some damaged bits which isnt so great...
Some more updates whilst packing stuff to move i've been reducing the amount of computer stuff to pack in the only way I know how... Building it ;)
Extracted and replaced these from the current build:
Fitted in the hidden underside, complete with the metal fan filters provided with the case - a word on the HW Labs radiators... Are they serious with how short those screws are??? Also does anyone know where to source spares, I need more and you don't get any extras for push pull.
Started to put the new fans on the top layer, not enough screws but they're on. I'm thinking i'll probably have the tube exit the bottom rad on the side depending on the route and run across the front with a flow indicator spinning in the middle of the radiator. No? Another word on the radiators, replaced ALL the crap white plastic stoppers with EK Nickel - i'm still not impressed with the white finish but i'm too stuck for time right now to respray...
Whilst packing I had a play with this little gadget from Hex gear, it seems pretty nice so hopefully it looks as good as I think on the blocked 1080s. Only thing is I realised they sent me the wrong one, 6+8 not 8+8... Bah!
Slow progress but progress. Backplates should be arriving early next week then I can officially start to transplant it all over...
Most rad screws (at least that I've come across) are either M3 (metric) or #6/32 UNC (see Wikipedia here for explanation).
M3 are the same as a lot of motherboard screws. You can pick them up in a variety of different lengths, colours and cap styles from auction sites - but delivery takes a while. A lot seem to be Allen key headed (hex). Black tend to blend in nicely.
Thanks mate, will have a look around - they seem to be M4 (0.7) so will have a look and see what I can find. That seems right to me as they are a little fatter than the EK screws which are M3.
Edit: Ordered some basic black ones for Tuesday, seen other more sexy looking anodised options which might be a consideration for the longer term project.
OMG, The backplates are here... :O
Just need the last couple of bits tomorrow and its go time!
Got one in green and one in white for a Welsh theme build
Dont suppose you know where the manual is online, want to check a few things about configuring the ports and mounting options (rotation etc)? Can't find it, the Monsoon website is useless... A photo of some manual pages would do - in short want to know how I can run the two in serial and acceptable orientations of a pump being fed by another.
Edit, alternative could be a dual loop with the two pumps directly mounted to the res... Thoughts?
Well finally the day comes when the Nickel backplates are in stock and arrive...
These things shine like you wouldn't believe:
Then excitement turns to utter frustration when I notice the bottom right corner, its damaged - basically the corners been heavily flattened (which must take some force on this!)... So I'm annoyed and I think well one has to get replaced...
Make that two:
Identical damage on both plates. :(
So annoyed I can't even describe it... Its not the DPD delivery, these were literally wrapped in tons of bubble wrap so I can only assume the box they came in was dropped heavily on to a hard surface - Dear EK you seriously need to pad the inside of the boxes as its super thin card. I don't know if this was on the way to OCUK but i'm about to log a ticket, please please please cross your fingers for me that they are not sold through because I can't do this build without them...
FML.
Hard luck on the backplates. It'll get sorted I'm sure but it's just a ball ache when you don't expect it.
Did you get a response from hex gear about the problems with the case? My R40 arrived with issues that I didn't bother chasing up because it's just a private home build, but it's concerning if quality control might not be as good as expected.
Keep the updates coming.
They've gone totally quiet, its a bit annoying - wasn't 'quality' really one had a chunk out the edge and pain on the front panel isnt amazing. Basically its all shipped over from China as far as I understand so if its got a bit of damage in transit thats life, instructions are crazy poor also but its a really nice case once together.
I've now got two nice shiny new backplates, an Aquero 6XT on order for Monday... Was literally just setting up to do some building and my heat gun dies after 1 bend. Seriously this luck :D
Probably have to wait until tomorrow now if I go and pick up a new one.
You can pick up an Earlex Heat Gun for £20 or £25 with a blow-mould case and a few extra scrapers etc. Seems to work well enough on low and it stands on its back to you can point it upwards and rotate the tube over it.
Well turns out the heat gun only broke on one setting so the 'omg burn the house down' was still working... It wasn't ideal but basically some progress - but in to the old case still. I was annoyed at looking at all the kit so I undertook the 1080 transplant in to the new blocks seems as OCUK sorted my backplates out, cheers chaps. I've done this once before but took me bloody ages!
One has to take a look at all the kit before getting started...
Time to get these bad boys naked...
Dear god EVGA thats a lot of paste!
Like A LOT:
Thanks to that it took ages to clean but got there in the end
Greebo costing me a fortune in 14w/11w pads instead of the free EK crappy ones...
Blocks on
BLING on... They look so good!
And... Repeat
Now theres some debate over the look of EK Terminals, but i personally like it... Looks clean, nice and simple and adds some stability to the SLI configuration.
Back in the old rig for now, while I wait on the Aquero and other bits to decide my final layout and then its go time. It actually looks really good in the current case:
And now i'm nackered so its beer time... But I feel like progress has been made! Any questions on the terminal etc let me know, seems like a nice bit of kit to me... Also notice the EVGA HB SLI bridge, thing of beauty and confirming that it does indeed fit with the blocks.
Well... Moving house is a pain in the behind.
I've made a lot of progress so plan on getting more pictures up as soon as possible (no internet at home) but i've hit a fundamental problem with the case. Long story short its just not fit well, the more I look at it the more I think it has some serious design flaws but the main issue for me right now:
The motherboard sits too low on (its on standoffs), which means I cannot mount PCI cards... Physically its impossible as the shroud hits the limit on the case before the card is fully inserted. I've also noted a lot of other issues which are restricting me from having the 'ideal' set up. Basically its a real shame for something which claims to be designed with modding in mind its really got some MASSIVE over sights which more build testing would have shown up... Right now i'm stuck with a £300 case that can't be used. Options are:
1. Parvum save the day and give me a case so I can show off my expensive kit and they can laugh at the competition.
2. Parvum unlikely to give me one... Buy one :)
3. Another case which will take my 480mm and 360mm radiator and allow some modding whilst looking good
4. Hex Gear resolve my issue, though I can't see how and everything is just ordered from China so I can't wait...
So annoying, pics to follow to show the problem and also some new kit i've got hold of :)
Hi Smffy. Rather than clog up JR23's log, I thought I'd clog yours up instead ;) :D
You said you were interested in splitting an Aquaero 6 so that the screen is mounted separately. To do it, you need to make up a cable to connect the two halves. It's all DuPont pins but they're not the usual 2.54mm (0.1 inch) pitch, they're 2mm pitch which means they're closer together and the pins are smaller. I initially though some ribbon cable would be the easiest way of doing it but once I'd finally found the right parts and started making up the cable, it dawned on me that it would result in the two columns of pins being crossed - think of two sets of two columns of 12 pins laid next to each, the ribbon would connect the left column to the left and the right to the right....but when the two halves are directly connected it's the right column that connects to the left and left to right. In other words, ribbon cable's no good and you have to do it as individual pins. You can get from eBay some wires that have a pin crimped on one end - which makes life a bit easier. I found these but the seller does not communicate at all and you won't get combined postage because you cannot 'add to basket' and he won't communicate. Stuff did turn up though for a couple of orders.
Pins
Wires
Shells
Crimper
Hope it's of help.
Pins
Wires
Shells
Crimper
Hope it's of help.
Its massively helpful yes, thanks for that - first thing I did was take it apart and think oh this looks a bit annoying so good to know your experience of it. Thankfully the old man is an electronics engineer so I think with your notes i'll just give him a little project while he's busy being retired :D
I've been pretty hectic moving house so its all delayed (plus the pain of the case as above) but one thing I have been doing is crimping and braiding a lot so hopefully that stands me in good stead for this one! Will post up some pics of that later all going well, now I've got internet again for a few days.
I'm thinking about never looking at his build again, its too good :mad::D
Forgot that you'll also need some pin headers as you need to convert one female plug into a male. I got mine from RS 636-5230 but you can also get them from eBay but they look to be slightly shorter and they're only just long enough as it is. Doesn't matter if they're longer than 2x12 as you can snap them to length - probably no reason you can't use multiple shorter ones either...just less convenient.
I think I managed to do mine with an SN-28B crimper....but I'm really not sure how!
Also worth noting that the only other thing I've found that uses these types of pin is the internal USB3 header. That's 2x10 though rather than 2x12...but it's the same crimp-pins if that helps.
Yeah, JR's builds are inspirational and depressing in about equal measures ;)
As promised, been very all over the place the past weeks moving but managed to pretty much strip down the old build and made good progress with this one until the case turned out to be utterly unusable due to the motherboard tray sitting too low and not aligning as it should... Still going back and forth on it and to be honest its dragging on longer than it should for a £300 case.
See here my key problem, sits too low and this is as far as you can actually sit the PCI cards:
Basically its useless, can't use the case so now completely stripped it down again and removed all fans/rads (not happy). The board does not align to the case well on top of the height issue:
And on another note the mounts once I really looked at them are so restrictive in terms of the radiator and basically will not leave room for push pull, i've suggested them move the fan mounts back 1-1.5cm as its easily possible and stops them sitting so far forward where you need to connect the front panel etc.
Anyway... While this has all been going on i've been learning to braid and tidy up the cables, i've ordered a load of connectors so planning to make some custom cables direct to the PSU to have a nice tidy build instead of the madness that often ends up behind the good stuff. the GPU combs look pretty nice when in in my opinion but each to their own:
Braided the Aquaero connectors, hated the massive cheap black braid it came with...
And finally I managed to get hold of this rare creature from Holland, complete with some mod kits and another EK D5 pump to complete my flow powered dream... It wasn't cheap but pretty much I just wanted a dual top and this is the only one I've seen that actually looks nice. The base plexi comes off and is not required so my plan is to drill out two holes in the mounting plate in the case and mount horizontally up the the notched grip on the mod kits. Secure then in place probably with some hot glue which will also absorb the virations...
The top, I replaced the black O rings with UV Blue - the front will also be replaced when I get round to ordering one:
Braided the pump cables ready to rock, connectors are still off as i'll probably trim them as I don't think they'll need to be so long.
And thats about it for now, the saga of the case continues - if its not resolved soon I give up and i'm ordering a Parvum L1.0.
If they're not prepared to fix it in a reasonable length of time, can you not return the case as not fit for purpose?
Braiding looks good. Have you got the wire crimped in the first 'wings' and the second set of wings crimped over both the braid and the wire's insulation? The guides I've seen melt the braid into the pin with the pin already crimped onto the wire but I can see your method making it easier to get the braid into the plug....as long as it doesn't make the wire more susceptible to pulling out the crimp.
Aquabus cables look good too. I cheated (perhaps) by running all four wires down one braid. Some blue to show up and some black where I want them to disappear.
Pump top is nice. Frosted looks nice. Have you seen that Alphacool have launched a series of hardline tubing with a satin finish? Just a thought, if you want to extend that look.
I like the 180 degree combs. Prefer the cables wrapping straight down....but it's difficult to get them then to exit cleanly. I've also seen a dual GPU with the top one 180'd downwards and the bottom one 180'd upwards so they meet in the middle and eclipse the cabling behind.
How did you measure the cable lengths so that they're equal after the bend? Did you do a rough measurement and cut them different length to start with or do one end, run them all and then trim to the right length afterwards?
The crimping is not yet done fully but yes first set on wire, second is over the insulation and braid then just melt it down - the braid has loads of space once you get it through the combs. In the connectors, loads of room...
Went for a bit of a mix of colours if i'm honest, i've got a load on order from OCUK then i'll aim to actually use one scheme throughout, its quite fun to learn it though and the ability to remove and replace connectors is seriously handy. It takes a lot of time, but it eases my OCD with the build and cables :)
The comb cables have not yet been trimmed but you can actually use them without cutting (basically start the exact same size then i'll possibly trim them). If you arc the cable, as you would if you ordered a 'rainbow' cable it actually lays together perfectly without trimming... I like the look, it works really well with the full covers to neatly run the cables down - although I could get my 'free' evga adapter. Inverting would be simple, literally thread it the other way but not sure i'm keen on it... Also work pointing out it acts as a really good brace to stop them sagging.
I'm loving the new alpha kit, have you seen the plexi res? Love it, looks amazing having the entire thing in transparent including the base - called Eisbecher i think. I'll defo check the tube but my long term plan is to replace with copper and have it black nickel plated, potentially open to change but I think ultimately depends on my case resolution... They are at least now responding, I ordered it in September. I'm going to try one more 'check' but then I think i'll just ask for a refund/complete exchange on it, it came with three damaged panels which are on order also so i'm not waiting on stuff from china forever.
Nice cable work and loving the detail man (Orings and stuff like that). Sucks about the case though, hope they sort it out soon.
