Hi Everyone,
This is just a small update, I have had a few issues with my CNC and it no longer works I have blown the spindle, so I have not done as much as I can hoped.
I have been painting the thermaltake Pacific P1 pump, this has cause me loads of issues, as I only get to mod on a weekend. I have painted this 3 time and I can see I am 98% happy with it. The photo below is showing you the process the 1st time I did it.
Before,
Pump by
Richard Ord, on Flickr
I needed to sand the parts done so the primer would stick to the parts, can I use spray can you apply the paint.
You can see the paint looks a bit bumpy, I then did some vinyl logos and added them to the pump and airbrushed the green paint on.
Here is the end result,
r
As you can see it looks ok but I want it looking better. So I striped the pump and started again.
This time I used the airbrush for every layer I also wanted to add green to the D5 cover and to the bracket.
I did this over a few nights adding one layer at a time,
I am much happier now with the end result.
I still have a lot to do, I still have a lot of wires to sleeve, fans to paint and a graphics card to paint.
I did hope to show more but I thought it would be best to post something than none at all.
Until next time,
Richard.
