Hello everyone,
So yeah, finally here is a build thread
- this was hugely delayed for 2 months due to my motherboard being DOA originally :'( - but its here now, without further ado here is Project Tardis!
The original idea was to have a small M-ITX build with a high spec, IE a lot of power in a really small package. The colour scheme is to be a mainly mono build of greys, blacks and a dot of white with small red accents to compliment it being a #TeamRed build
So the spec:
Case: Fractal Design Define Nano S
CPU: Ryzen 3900x
Motherboard: Gigabyte X570 I Aorus Pro Wifi
RAM: Corsair Vengeance LPX 32GB DDR 3200mhz
Storage: Gigabyte PCIe 4.0 1TB Aorus NVMe
Graphics: Gigabyte Radeon 5700XT 8gb Reference card
PSU: Seasonic Prime Platinum 650W Modular
Cables: Cablemod custom length PSU Cables
Cooling
Pump/Res: Alphacool Eisstation
CPU Block: EKWB Velocity AM4
GPU Block: EKWB Radeon 5700XT
Radiators: 2 x Hardware Labs Black Ice Nemesis 240GTS X-Flow
Fans: 4 x Noctua Chromax NF-F12 120mm
Coolant: Mayhems Pastel Light Grey
Fittings: Bitspower
Tubing: Mayhems Glass - 12mm OD
So as mentioned, originally some 2 months ago, when I finally had all the parts. I assembled the PC on stock cooling with the intention of doing some stability testing. The motherboard however, had different ideas. The PC posted twice, then after that it just wouldn't
Frustrated, I returned the motherboard and only got a replacement on Friday just gone (October 25th) so a whopping 2 months for the RMA process, annoying...but outside of my hands, oh well.
Anyway, so this Friday just gone. I assembled it all on stock cooling and booted up. Updated BIOS to Gigabyte F6b and got Windows installed, all running exactly as it should
After 48 hours of testing, I am happy. Time to get the WC installed...this is the tough bit.
First bit, GPU block on the GPU
Using the original reference backplate as I think it looks great with the red accent.
It's on!
Next up is CPU block
Original cooler coming off
CPU Shot
Stand-offs in
Block on
After this I decided to get the radiators fitted and identify the correct position for them
Radiator position confirmed, time to do the first tube fitting, also arguably the most awkward. So these radiators are X-Flow rads, now I had this "brilliant" idea to save space by having 2 corners of the opposing radiators line up, so it was just a straight connection between them.
And in my defence, it did work!
But christ was it awkward
(sorry for potato phone pic on this last one, forgot to snap one with the actual camera!
Now, throughout the day I quickly found that cutting the glass tubing was damn difficult with the tools I had available so decided to rethink my strategy and call it a day at this point. I am going to take a different approach using a Dremel and diamond cutting disc.
Pump/Res isn't fixed yet, just getting an idea of spacing.
But today my Cablemod custom PSU cables arrived...I am in love!
Therefore tonight, the cables got fitted!
And my god, I freaking love them
So clean with the exact look I was hoping for!
Next Steps: Diamond cutting discs have been ordered and due to arrive Wednesday. From here I can then finish plumbing in the loop and look to fill it. I also need another 4 pin PWM Y-Splitter to hook up the pump/res to the power properly.
Oh, also take a sharpie to the edge of the GPU PCB
Thanks for reading this far. More updates later in the week all being well
So the spec:
CPU: Ryzen 3900x
Cooling
Fittings: Bitspower
It's on!
CPU Shot
Stand-offs in
Block on
