Anyhow the putting together the front - 30-09-10
Lots of lube for the ARB bushes
All bolted up with the LCA compliance bushing (not torqued up)
Doing up the drop link to the ARB end only (RH)
Stick on the hub assembly. Drop it into the LCA where the ball joint sits then do the castle nut up on the camber arm to lock it in (don't forget to slide in the drive shaft.)
Get soem copper grease on the hub nut. PLanning ahead for future removal as this is tight @181Nm
Pics of the castle nuts on the TRE and lower ball joint
Bolt on the fork to the LCA and slip in the damper. THey don't line up well, so only loosley do up the nuts in teh engine bay holding in the damper assembly.
Pretty much all done up.... YAY and doesn't it look pretty.
NOTE: WHEN TORQUING UP READ MANUFACTURERS RECOMMENDATIONS, especially when using OEM bushes as they have to be torqued up under loading, polybushes don't matter so much as are spherical bearing type. I put a block of wood on my jach and raised the whole suspension up anyway just for being pedantic and making sure everything was loaded thus seated correctly.
Pic of the drop link area all done up.
Adjusting camber. To drop the suspension down you must undo the droplink nut that holds it to the LCA assembly. The whole suspension easily move down giving access to the SPC topside nut on the ball joint.
When adjusted to 120Nm you just jack up the suspension again and do up the drop link to hold it up.
Cotter pin in and sorted (do the cotter pins on the TRE and Lower ball joint castle nut too)
Showing off pictures, especially love the first one!!!
Mamimum slammage on default setting the MeisterR's come set as. Far too low but looks awesome!
