Project: Temjin-M
When you say you're going to finish your TJ07 first, will we have pics/everything installed or are you just going to bin it as is?
Iirc, last update of it was mobo tray out of the case in a mess on your desk.
It might be a mess... but it's MY mess!!!!
Yes, TJ07 will be finished and put in case and used every now and then for web browsing
cleeecooo, to get better pics use a torch to brighten up the subject and a tripod if you have one, but with the torch, try and get it angled so that it doesn't shine directly on the subject, just adds some light to it :)
also, my new project is live :)
Thanks for the tip :p
I'll see if i can get a tripod of some sort.
Already commented on your log :p
If you can't get one, then try using some books to elevate the camera, and also, use the timer to avoid shaking.
yeah, I just realised that after posting that :p
Ok, trying to get an aquaero pro :D
Oh, also, damn you rjk! I got this case to try and stop copying you and i'm doing it all over again :(
