Project: Temjin-M
overuse of spoiler tags mate.
people just wanna see your pics :)
Apologies, thought itd neaten thugs up:p
I'll stop usig them
loving the hourly updates
unlucky on the psu, the sleeving pretty much warranty voids it.
PSU was overheating, and is on now.
It's 100% modular and I have a spare set of cables so it's all good :D
done a proper cleanup and removed all of the unrelated spam from the thread.
again :rolleyes:
Thanks for another cleanup rjk :(
Ok, I've had a look at the case and it is HUGE!!!
I'll get some pics up of it next to my TJ07
My pland have changed slightly. I think i'll have CPU, and GPU's in one loop using a 480 EX rad at the bottom.
Then have another 240 mm EX rad in the bottom for mother board an two RAM blocks.
I think there may be space for another 120 rad up at the top of the case and I might add another EX rad to the roof there
Another option would be to cup the back of the case up and get a 360 rad there.
Yet another option would be to replace the two 180 mm fans at the bottom with radiators running passively, but I can't seem to find 180mm rads. A 200mm rad simply won't fit.
Drive bay wise, from top to bottom:
Blu ray drive
Res 1
res 1
res 2
res 2
HDD
Aquaero
If possible, i'll fit the aquaero in front of the HDD drive, then i'll have 3 drive bays left where i might mount another 120mm rad
Opinions?
I'd love to have the tj07 ;) you could have a 360mm rad mounted with some adapters to where the two 180mm fans are currently like you can in the rv02
oh and remember when taking pics, put the camera on the tripod, put it on a 2 second timer, and make sure your shadow isn't in the shot :)
Got any loop routing ideas yet or you waiting until you have decided upon your what radiator goes with what?
Also what watercooling equipment have you decided on? I didn't see a list of what you are intending to use, or is it coming from the scrapped S build?
As you are set on having 2 loops personally I would keep the CPU and GPUs in different loops depending on how many radiators you go with.
Just a few ideas out of your many options.
2 Radiators.
Dual rad == CPU + ram + mobo?
Quad rad == GPUs?
3 Radiators.
Dual rad == ram + mobo?
Quad rad + 3rd Rad(240 or above) == GPUs + CPU.
or
Dual rad + Dual rad == CPU + ram + mobo?
Quad rad == GPUs?
he is using the watercooling stuff from his old log, pretty sure it says in the op, I'd also say that the 480 rad would be best for the cpu, mobo and ram and other rads for the gpu's
O ya it is in the OP will need to take a look at what he is using (or the OP could be updated with it...)
Was just a few ideas really, as I'm new to WC I'm not 100% sure where the most heat will come from considering the use of 570 SLI thought that might be it.
Either way im looking forward to this.
Cleeecooo
King Damager
Hyburnate
KiiYzOo
are you reading my posts?
either the thread goes back on track and conforms to the rules. Or, I close the thread.
This is a project log that should be presenting information and progress, not giving a list of hardware faults and the status of how tidy the OPs bedroom is.
If you want to chat. use MSN
I have had to remove 79 POSTS from this thread that do not conform to the rules.
Not a single other project log in this section has had this done to it.
***Project Logs Rules and Guidelines***
Project Log Section Rules
  1. Your first post must include an outline of your plans, as well as pictures of the hardware or concept sketches of your ideas. Your progress posts should include answers to questions as well as pictures of any progress.
  2. If you have finished a build but not taken any progress pictures of your work, then please post it as a build log but try and give a review of your thoughts on the case and how your build went including any shortcomings or cool features you found.
  3. Do not post threads with links to your work from other forums. If you wish to use this forum to showcase your project then please post the full project here.
  4. Picture sizing should be kept to reasonable scales. Please do not post huge pictures. There is no specific rule but try to keep in the range of 800 x 600 or lower.
  5. If your pictures disappear then the log will be removed.
  6. If you feel that a comment is unneeded or against forum rules, please use the RTM function and it will be dealt with accordingly. Remember though, if you are posting your work for public viewing then you must accept some critique.
  7. Try to update the log at least weekly, answer any questions and add any updates. If you are going to be away from the forums or putting the project on hold then please outline that this is the case. It frustrates readers when they start reading your worklog only to find out that you have decided to buy a Mac and not told anyone!
  8. Keep threads on track. Do not spam a project log with irrelevant questions or off topic posts.
  9. NO IMAGE QUOTING
I thought hardware faults would be allowed considering they're part of the project :(
Anyway, UPDATES!!!
Macro of CPU socket:
CPU and RAM installed:
Waterblock installed:
First graphics card in:
Both cards in:
Internals:
GHETTO!!!!
GHETTO with monitors!!
I hope this makes my log more of a project and less "pure crap" :mad::mad::mad:
EDIT:
corroded block
pics are looking much better :D you got all the watercooling stuff you need? are the cards working?
also the corrosion seems like it's come from the seal between the middle screw and the block
I'm still waiting on The aquaero.
I need to order another ram block and mobo blocks, then some plexi tops for my pimps :D
I've contacted EK about corrosion. Not sure yet about the graphics cards.
nice pictures, what plans do you have for the tubing layout of the new case?
is the corrosion down to the bare copper on that block?
was that the loop using pure water that caused that? you didnt use any biocide in the loop or anything did you?
one thing i have noticed, my TJ11 is a real hassle for cable management, looking forward to seeing how you do yours.
I have a few ideas but nothing set in stone yet, either way it will be far more of a hassle than a TJ07 due to the motherboard orientation.
are you planning on doing WC through both memory sets?
personally a WC block on each memory bank with and the loop going
memory>CPU>memory would look sweet.
also
please don't think I'm being harsh with my cleanups, I am the only moderator of this section so the less work for me the better.
Keep up the good work mate :)
Yeah, RJK, I thought that talking about faults with hardware was relevant to the project as it is part of the project.... It seems I misunderstood though, so sorry that I was talking about irrelevant stuff.I don't think you're being harsh, I just yeah, clearly didn't understand. So sorry.
Have you got power to the rig yet. It looks like you could do some tidying up of the loop in due course though :p
Are you going to mount rad in top or in bottom instead of HDD bays, pretty sure I've seen both done before.
kd
I'll reply to the posts above once i have windows sorted out
But here's a pics of the 3930K next to a 2500k
EDIT:
MY graphics cards are refusing to be acknowledged by nvidia control, panel. think this may be the problem:
sweet jesus thats a monster chip or does that photo just make it look bigger?
although when done right watercooling ram can look nice......but its a lot of expense and hassle to go to for minimal at best gains mate...i had some ocz reaper water cooled when ddr2 was out, it cost a fortune and needed special koolance ram spliters that were from memory £25 each (2 needed to cool the 4 sticks). once there under water you cant just pull them out either it starts making things awkward if you like to keep playing....which you obviously do ;)
personally i just water cool chip and vga now...means i can still play.
just bought the same ram kit as you i think also 16gb dominators @ 1866mhz c9?
i have a airflow 2 fan and i bought the airflow pro also for a big of bling :)
