Project: Temjin-S
de-ionised water/purified water, if you don't have enough then flush it a couple of times with tap water, then once with the de-ionised/distilled
just wanted to point out, this thread has been taken over by you two :rolleyes:
what happened to the general chit-chat being kept on the other thread.
UPDATES AT LAST!!!!!
Well i'm £4 short of sleeving so I guess it will have to wait - again!
However, I've setup a loop outside my comp to test fro leaks and to flush the rad and try to clean some of the grime out from all my second hand bits :/
I am not using any of the new stuff (apart from rad an fittings) but here's the loop:
When the sleeving arrives, i'll take everything out of the case, start doing all the mods i'll need to do and I will also liquid cool everything when it is out of the case. Then, I will do the liquid cooling properly in the case when it comes back from the powdercoaters :D
