why did you use so much tubing, having the pump down there?
1. to test its capabilities
2. it was the easiest placement
don't the cathodes hurt your eyes?
Are you going to use 480 and a 240 rad and the D5 pump at the bottom? Do you have enough space to put angled compression fittings(45 or 90?) after fixing the fans?
90 degree compression fittings?
I'm using a thick 480 and a thin 240 and the 480 will have push/pull and possibly the 240 and i'll use angled compressions for those. The pump will sit at the bottom of the drive bays.
I'll see if the pump fits at the bottom with both rads though
Sounds exactly like my plans. Just I think I'll only be going for push or pull. Don't think both will fit.
Any idea how long until you do the tear down?
pic coming...
