- 23 Sep 2009
- London
Project: TJ07 Revived (on Steroids)
Yeah, yeah I know you're going to say every Tom, Dick and Harry has done one of these (I did one 4 years ago here somewhere) but it's still a great case, if not outdated and I don't want to replace it
. And done properly (with careful planning of cable management, etc), these builds still look fantastic.
As you can see above it's not just replacing a bit of tubing, I'm replacing a lot due to corrosion and being inspired by other builds online, and a new GPU and Controller (My Scythe Kaze Master fried due to a leak a few years ago and gave false readings), but retaining the motherboard and CPU.
So the spec as follows:
1) I'm going to need two 120mm fans for the roof mounted rad & 2x92mm fans for the rear, I'm thinking the Noctua NF-F12 PWM "Linus Tech Tips Special Edition" unless there are fans that would better match my colour scheme
2) I know there are going to be a lot of things to cram into this case, but it's a big case and hopefully I can manage it, I got a bit carried away with my shopping list hah
3) Loop order needs careful planning, ball valve for drain with cutout from the rear to attach a tube to it when needed
4) Might need to drill a fill loop but if I can get away without doing it I will, the tube Res has multiple inlets at the top! Filling via the Bay Res is also possible but I don't want to run the pump dry so will fill both.
5) 3x D5's in total just because I wanted redundancy in series and a boost of pressure as I have quite a few 90degree bends, but also because I want a bay res in the front bay
I'm in no way a pro at this, this is my 3rd watercooling attempt since 2010 and the planning I'm putting into this has been from being inspired by other builds and the experience from the first 2.
Please do provide me any feedback you may have as I really could do with other opinions as I do tend to get carried away
Will update later, watch this space.
- Intel Core i7 950
- P6X58D-E Motherboard
- 3x 4GB Corsair Vengeance PC3-12800 CL9
- OCZ Revodrive 350 480GB
- Asus GTX 980Ti OC Strix 6144MB
- XSPC AX240 Radiator
- XSPC EX480 Radiator
- Magicool 240 Slim 16fpi Radiator
- AquaComputer Aqualis Base 450ml w/Nano coating & Fountain effect
- AquaComputer D5 Pump Adapter with fill level sensor
- AquaComputer D5 pump motor with USB and aquabus interface
- AquaComputer Flow Sensor 'high flow'
- AquaComputer Filter with Stainless Steel Mesh
- AquaComputer Aquaero 6 XT
- 2x AquaComputer 4 pinAquabus cables
- AquaComputer aquabus Y splitter
- 4x XSPC 5mm Twin UV LED to Molex
- Primochill Vortex Flow indicator
- 2x XSPC D5 pump motors (from an old XSPC Twin D5 Res that has corrosive stains that won't go away, planning to stick them in a Alphacool Repack Dual D5 Bay Res, because I like it
- PrimoFlex Advanced LRT Flexible Tubing 1/2" x 3/4" x 2m
- EK Chipset & Mosfet copper waterblocks for Asus X58
- EK Supremacy EVO
- Kryonaut Thermal Grizzly
- Mayhems X1 UV Clear Blue
- Mayhems Blitz Pro
- Various Chrome fittings
- Koolance VL4N Quick Disconnects
- Scythe Gentle Typhoon's
- UV Led strips & UV mini-CCGL's
- Distilled Water (for flushing and leak testing,etc)
- The legendary Silverstone TJ07 w/Side Window & couple of modded cable management cutouts
- Matt Black adhesive Vinyl
- White sleeved extension cables
- Phobya & Bitspower water temp sensors, (probably won't be that accurate with the Aquaero but I have them lying around, so...
- Other things I forgot to mention which I'll mention as the build progresses
