I'll be able to get all the cables tucked away once I've filled and leak tested the loop with a spare psu.
Don't kid yourself; you'll shove the lid closed (if you can) and forget about it like the rest of us!
I saw a wasd keyboard and mouse for the ps4 yesterday! Would seriously consider if OCUK has it!
Don't kid yourself; you'll shove the lid closed (if you can) and forget about it like the rest of us!![]()
Hahaha..you got me
I'm no JaysTwoCents so there's no way I'm going to make it THAT clean.
To be fair if you take a bit of time you can get it looking great, it helps air flow too...problem for me is the CPU fans and that kind of thing!
Well, no ones going to see the cables as they're all in the rear. And everything is watercooled so no issues with airflow in my case (pun intended). The rear doesn't matter if its hidden behind a case, provided the case panel is able to close.
Spend 20 minutes with a few cable ties and you'll be proper pleased with yourself
I'll post mine (if) my new motherboard and cable kit arrive by Friday![]()
) Air bled, Mayhems Blitz Pro Part 2
All those iron filings, scary, I'll be flushing before I build for sure
Looking good. A disturbing amount of metal filings after the flush but at least the filter caught them. If you've still got it empty it may be an idea to check that none of them are caught in the pumps. I don't know about D5s but on a DDC there is a separate rotor that sits on a bearing and is spun electromagnetically. Because the rotor is a magnet, it can 'grab' metal filings as the come past and you don't want them abrading the bearing or any other part. If the filter is before the pump's, you're probably fine.
One thing to note though. The valves on the filter don't bypass the filter, they're just ball valves and shut off the inlet and the outlet (one valve each). The change of pitch of your pumps will have been because the flow stopped but the pumps were still trying to push the coolant.
Some issue with the USB3 ports however which I'll need to look at. I've looked at the 1366 X58 Xeon 5650 thread where someone had this issue for years until they upgraded to a Xeon and realised their PCIe frequency was set to 101 mhz instead of 100 mhz! Or something to that effect.How goes it? Gaming yet? Did you get the lanes issue sorted?
Hey man is that 13/19mm hose and fittings you are using?
Love the rig too. Hoses are growing on me again.
Beautiful! Love the UV glow![]()
