You're unlikely to find much difference in flow at different points in one closed loop. If there is its because you've got problems with one res emptying.
Yes, if you connect the return to the bottom centre it rises up the central shafts and fountains from the top - provided the top centre is blocked. If you connect it to the top centre it will fill the shafts and fountain out the top - provided the bottom is blocked.
Aquabus can be split if you need. There are specific aquabus y-splitters but they're just the same as a fan splitter or PWM splitter. All they do is connect each wire to each device - so you could split the connection and the run a cable to each device or you could run the cable to one device and then have the cable connect from there to the next device like PSUs do with molex power wires.
Bitspower are good...just not cheap. Are you aware of Barrow? Very similar but cheaper and without the logo.
