Project: TOXIC GREEN
Working on the cables today
Here's how neat and tidy they will be, 24 finely cut holes in the same panel as the res.
Few updates today
LED's arrived for the Toxic and wires, placed a fan screw next to them to show the size
Burnt the wire ends, frayed them and put 2 LED's in each end
Green Constant LEDS for the toxic
Buried into the silicon
new fittings arrived to finish the loop
And finally, the single UV 5MM LED to backlight the Res.
Drilled out the holes for the VGA cables
Connected the GPU and turned the beast on to make sure it all works.
got new dye for the silicon as the other one failed.
also got myself a pen blow torch for burning holes and putting in the cables.
Back to work, now dying the silicon.
Also working with the blow torch tonight to burn some holes in the plastic!
Wish me luck lol
I can now confirm the RAM being used and the SSD's
Please note these have not been released yet and i will have them here next week or so.
First up the Avexir S100 SSD
There aren't many photoi's of the green SSD's around. But i'll have the green ones.
THE RAM!
Now there's not an expected launch date and i cannot show you them working until computex 2016 where the build will be unveiled featung the new Tesla Range
Avexir Raiden Tesla GREEN
Also
I managed to get the right pigment and thinner for the silicon YAY! so now i can get to work on the drippings.
Looks cool! You spent a great deal of time on it.
Thanks man! Yeah it's been a while in planning. 2 months on the actual work so far.
Update:
Managed to get around to getting the window frame cut, chrome sponsors names cut (i cannot show you the unedited picture due to direct competition of overclockers)
Also got the roof fitted to make it look even cleaner.
I'm amazed at how much of a difference some chrome acrylic can make to a build.
It went from okay, to show quality.
Patiently awaiting the arrival of the new RAM and SSD's from Avexir.
Managed to fit the new lights, igniting the green and making it glow!
Once the RAM arrives and i get an actual size (the RAM is pretty big) i'll be able to fit the burnt out cables, burn the holes in the plastic, add more toxic and fit the SSD to the bottom right corner.
As it looks tonight
Yes that is a cable tie holding the res in place, a little later on i'll put another cable tie in the bottom, to secure the res while it's traveling to taiwan.
(last thing i want is it to arrive broken)
You're in for a treat guys!
Introducing the tesla green Avexir raiden RAM in motion!!
More to follow this afternoon, and pictures of the new SSD S100 Series from Avexir
introducing Avexir's new SSD range. The S100!
Built for gamers and modders, this SSD is sure to look good in your system.
I've got the green version, but you can have it in almost any color you want!
I'm not sure anyone would have noticed had attention not been drawn to it. Wasn't aware of them but checked them out and they don't have the range either of product or price that OCUK do. Clearly therefore not competition so clearly not a breach of the rules! :D
Loving the build too, by the way. Was really unconvinced when you were describing things like the slime at the beginning but now it's a reality, it works nicely. Looking forward to being convinced about the burnt out wires now too :D
They're just a long time sponsor, have been since my first project. Unfortunately it was against the rules at the time, so best not get myself into trouble :P
Thanks :P glad i convinced you.
The wires should look epic, if it goes according to the pan in my head ha
Introducing the final pictures
This monster has taken months to build.
there was ups and downs, many ideas i couldn't complete while new ones cropped up and filled its place.
From here, the build will be boxed up and shipped off to Taipei in taiwan.
i won't see it back until mid summer.
Final specs
Intel i7 6700k
Gigabyte G1 Sniper Z170
Avexir RAM - Avexir Raiden Tesla Green
Gigabyte Xtreme gaming GTX 970
SSD - Avexir S100 Green LED SSD
Thermaltake Riing fans - Green
be quiet! Straight power 10 - 800w
be quiet! Silent Base 800
Here's some photo's
Waiting until night time to go outside and get some really cool photo's done.
Once it's at computex, i'll get some photo's done of it on show.
I didn't move ahead with the sparking wires, because of the seller who supplied the lights claimed they flashed at random.
In fact they do not, they are constant and with time being strict, i don't have time to order more and get them fitted.
This sucks :( but the project already on a time limit right from the get go.
MT. Mods
