Well it stayed in one piece, mainly...
Lost a couple of header bolts during the afternoon and all the cam cover bolts loosened resulting in more oil over Dans dyno!
Its mapped from 20% to 100% throttle and runs nice, runs better a little leaner than normal turbo bikes and it may need leaning out a bit more yet.
Weirdly it makes the same power at 70-80% throttle as it does at 100% but it requires more fuel, not sure how thats working but its something to look into.
Ended the afternoon trying to get a smoother idle and stop the jerking at low throttle openings.
Sadly no end of day vid as Dan had to shoot while I put the bike back together.
So a good check over is needed and its safe enough to get some road miles on it before the next dyno session to iron out the low rpm running and see what kind of power it can make.
