- 21 Dec 2019
- Planet Thanet
WOW that's a Lot of gear for the money mate
Am insanely jealous I don't have a friend in China or Hong Kong lol
Guessing that's just a little bit of the anti vortex plastic that broke off
If want the res attached to the pump
Few options
Check if the end of the res comes off and leaves the pump able to be fitted to it directly
Or use a male to male extension
With those you have to attach pump and res before it's in the pc~unless it's a rotary male to male
Or use an adjustable sli fitting
Or somewhere I have a friction fitting for doing it
One half screws in res one in pump then you just push them together
This let's you mount your pump then can just push the res on
First time used those was scary as held together with 3 or 4 O rings friction
But worked great
They are useful for when things are too tightly spaced to get your hand in to turn fittings etc
Few options
But worked great
