Project: XBOX Supreme
Update 30-05
Here we go again....update time
Had the tray of the Xbox board disassembled and painted it black
This is better than the aluminum look.
Exchanged the original rivets for black ones
scotch tape on it from damage the paint
Nice flat and black
Also did some brainstorming for the window and got some nice ideas presented. I am going to try engraving this time.
So after some practice and see some movies
For the lines I use a diamond point bit
And for coloring / Shadow effect I used a diamond tip
First some practice on a scrap piece and then ............. the real work
with a steady hand you'll do quite well. The first angle
In the dark, and an LED strip behind
And yesterday, the second part done. Pretty funny this engraving ;)
And that was the update for now......you like it? I know I did
Grtzzz.
Quite like the idea of engraving the window... I don't really go along with the tribal style designs though... Prefer something... 'darker' ;)
Kier, I looked through your other builds and You've SO made me want to copy Lightning McMod for my kids!!!! I love it!!!
Had a quick skim through as I'm about to pop out.
Looks nice so far! :D
Where did you source the case from? Finding it a pita to get a hold of.
Just wow mate. I admire the skill and lateral thinking needed for something like this. I have always wanted to do something completely modified but I just don't have the time.
Keep the pics coming
Sub'd
Yeah personally i dont think the tribal stuff fits.. Its the sorta stuff you see just above a skutters butt crack or down the side of a chav mobile.. I woul dhave thought something more fitting for the 360 would have been nicer.. Maybe Halo logo or something tech based..
Maybe a faint tracing of a circuit board?
Not sure how hard that would be (probably VERY lol) but I think that'd look awesome :D
I think overall it looks fantastic but personally I would leave the window plain/clear.
no competitor linking please
Update 02-06
Today did the final touches to the engraving. Like this engraving thing
we gonna do this often ;)
The black painted parts are also placed back
And I was brainstorming for the watercooled components. Pump and the 250mm Reservoir
The EK Supreme's with BP fittings
Reservoir next to it
We fill under the xbox drive. This gonna make a plate with a hole for reinforcement
He goes from the pump in to the first block
And from the second block he goes into the radiator, and from the radiator back to the reservoir.
And two last pictures of the hardware with window
This is it!!!
Grtzzz.
