Project: XBOX Supreme
no competitor linking please
Update 04-06
Just a hardware update. Yesterday I received from a friend (thanks Marco) a second-generation Xbox, with a Falcon Xenon GPU on board.
The layout of the PCB is also some different and better looking, it is much cooler and therefore less likely to give the RROD.
Old PCB:
further in the update photo's of the new print
On the this new board are placed some capacitors, where some data is printed on
To have a nice clean print I get the caps cleaned with acetone and after some brushing the become quite clean
I've also been busy with the tubes. From pump to the first EK Supreme
And from the first to the second block by BP rotery and multi-link adapter + Custom acryl tube
And from the second block to the black ice 120mm radiator with Tygon R3603 tubing
First part is finished.
From the output of the radiator to the reservoir
And the loop is ready for use
As you can see the new print varies somewhat with the old, and is much cleaner.
Have a nice weekend!!!
Grtzzz.
Looking good!
Love the idea of the graving, but I too think that tribals doesn't quite suit (although they look fantastic :p)
I agree with the tribal designs, they don't suit it and spoil the clean look.
However the hardware looks amazing, the loop looks so neat :D
Thanks you guys, maybe I can change your minds about the tribal thing ;)
Update 05-06
I am on a roll with this project ;) A few things to do like:
A paintjob of the DVD player
Disassembled xplayer
And after some layers, a black box. On the DVD there was a clear round sticker. Placed a white sticker in the middle of it
I want to place the reservoir without the holders, so I have a made a piece of mesh
Painted it black an made a hole in it
Placed like this
Put everything together
And the picture of the mesh with the hole for the fill port
The fillport under the DVD, which is holding the reservoir in place
And then ....... the best job, filling. The well-known Feser One UV Acid Green
Tasty poison green
Cheers!!!
And fill it. First a little bit for the leaktest
And after some hours the rest
After some rinsing and waiting Feser becomes quite "calm"
There's still a lot of air in it, but will disappear eventually
Front also quite nice. Reservoir is good to see through the mesh
And another picture of the tribal panel
There are some nice things that i’m gonna do with the radiator and a double bottom for the cables, so he's not finished yet ;)
Grtzzz.
That stuff is extremely green, though as I'm a pedant I do have to point out that acids aren't. :p You did a very nice job of the engraving regardless of what people think of the pattern by the way!
Thanks. I'm gonna send Feser a mail
They called there Feser one fluid, UV "acid" green :D
Awesome!
I actually like the tribal design, but that's probably because I have a tribal tattoo on my left shoulder :p
what are you running the pump off?
also, please take note of the no competitor rules on the forums.
12v power from the xbox board (fan connection)
I removed the link allready didn't know that the banner also was forbidden
My apologies, won't happen again
btw wanna show you the 3 generations of the Xbox360 ;)
