Thanks for the info regards the numbers but it looks like they have changed the interface again as I don't see them anymore.
Ditto. I think maybe as part of version 2?
Have you had any issues with the Fibaro dimmers
Have only set one Fibaro dimmer up yesterday and yes, have had an issue, although it's not either of the ones you mention.
I am having issues with the dimmer more or less falling asleep. It works when first powered up then coming back to it after a while the switch can be unresponsive, fiddling about can get it working again. Initially I thought maybe a wire was loose but they are all good.
From a little Googling it seems S2 can be buggy on 2.2 firmware devices. One suggested fix is to change param 10 to 0, disabling the soft dim up/down when switching on or off. Only just made the change so will see. Annoyingly those threads are from 2013 so not sure if/when there will be a proper fix.
Pics please
Will get some up of the various things I do. At the moment not much to show, yesterday was setting up my first dimmer which meant ripping out the original 1960s wood back box. Conveniently a 35mm metal box fits pretty much exactly in the hole it left, just a little fiddling to get the wire in the right spot.
I should probably have said "Worktop lighting" rather than "Under cabinet" I think. I have some
Ikea OMLOPP LED worktop lighting plugged in to a TKB socket in the under stairs cupboard we put in.
Plan is to set up a dimmer in the kitchen with the first switch controlling the main ceiling light and and use the second input to switch on that plus another set on the other side of the room. It should be a nice upgrade for us without too much disruption.
Currently there is a single light fixture in the middle of the room, with 4xGU10 spotlights in it (just changed from 4x50W Halogen to 4x5W LED). The single light works great to light the room, good for looking in cupboards etc, but wherever we're stood chopping we have our back to it.
It would be a pain to change to spots as the rooms above are laminate or tiled floors. The house is all brick and only a few areas are being redecorated, so hoping Z-Wave will be a big win by avoiding too much disruption, in addition to the automation / iOS interface aspects.
You're going to have to experiement I think. What I did instead was in my bedroom, associate the Fibaro dimmer with the POPP dimmer socket so when I dim the main light, the table lamp dims with it at the same %.
Thanks. Not fully decided yet whether I want everything on one switch or main lights on one switch and under cabinet & ancillary lights on a second but that is does sound like a good option if we go for the former. There's a TLC down the road that has the K4885 switches at a reasonable price so will likely grab a couple to test.
