project :)
whoop dee whoop! finally got a little more done, was tired after finishing at 8pm and begining at 9am :eek: anyways, removed the fdd bay, i have put some material down to sound deaden the case, cathodes been plugged in but yet to be cable managed:mad: and have got the res in and the rad (although i got to reverse the fan as it is pulling air in to the case through the rad and i want it to blow the hot air from the rad to the outside the case)
flash on
a bit of glare
not the best pics as im in a rush to get to bed, you can see the pump is in place ( checking positioning) hopefully tomorrow night i will
  • braid the pump cables and then install pump
  • make mind up on cathodes
  • small leak test
  • make everything neat and tidy
chances of this all happening is slim as i still need to cut a hole at the top of my case to finish the cable management out!
anyways
comments welcome :eek::rolleyes: :D
looking nice - isnt your phone an lg viewty? sure they can take better pics than that!
arent you supposed to test the system for leaks before installing it?
shakey hands dont help with any camera :p
depends how risky you want to be, it will have a small leak test, each tube end will be clamped so the only leaks i would be worried about is if i have burst the rad or something :eek:
FInally got the watercooling in this little mo fo :)
started it at 9ish after finishing work and turned it on at 10ish so a quick job, i hope i did it right :p
shall leave it on over night for a small leak test, only had two small leaks when i first turned it on
so next thing/s to do are turn fan around :p mount rad+fan, cut window, silence hard drives (possibly bungee mod) get some carbon fibre done on the insides and maybe have some fun in between all that :p
all comments welcome good and bad :eek:
SG
