- 22 Jul 2012
- London
No probs mate
Despite going to water, I had a hell of a lot of fun doing the aircooling thing and still find this stuff fascinating.
Use an eraser to clean the sticky pad residue from the VRAM/VRMs and it's probably best to use TIM cleaner/Arcticlean/vodka
D) for the die. I just used a bit of kitchen roll to wipe it clean tbh
You'll see what screws need to be removed to get the main cooler off the card. Remember the two small ones attaching it to the PCI bracket too!
You may have to give it a slight twist and/or a bit of leverage to free it from the stock TIM and the thermal pads though. Don't use too much force and with small movements it should pop off without too much trouble.
