Caporegime
Meh!!! We need another Uncle Peter DIY cooling solution. Cmon Pete, you know you want to
A couple of these MK-Dons will work nicely.
Hahaha
Thanks for the weight info. 550g is not all that much! Guess it is mostly aluminium though, my 580 waterblock weighs just over 700g!
You can see where my concern from weight comes from now. Wonder how much a 7990 block weighs...
Sweet. That's a lot more viable for many.
The accelero's are around the same price as the MK-26, so it's unlikely...
They'd probably sell more though.
Out of the box, the MK-26 is probably the better solution, but the Peter would likely beat it if you went to extra lengths like cable tying a couple of 92mm fans directly to the heatsink and using the pci fan bracket to mount a couple of side exhaust fans.
I swear the price has changed from £505 to £525 and now £551 for this...
I may be wrong about the £505 one.
Right then
Some more information here to answer drunkenmasters questions and hopefully explain a little more about the setup on this card.
this picture shows the rubber underneath the backplate and the mounting method as well as the half height heatsinks next to the heatpipes from the cooler.
