PS style controller for the 360?
And the best d pad there is, which is important if you play pro evo.
The 360 pad on the other hand has by far the worst d pad there is.
Personally I do still prefer the dual shock design for all but 1st/3rd person shooters.
The 360 pad is great in general, but it's got the worst D-pad ever and the triggers aren't good for games like Pro Evo.
If there was an adaptor, I'd definitely buy one for playing pro evolution.
now you mention it the d-pad is pretty lame on the 360... I have accidentally pushed left when I meant to push up etc countless times - they should make them individual buttons rather than one big round thing!
It's strange how the 360 pad feels so much more well built than the Sixasis considering that he PS3 feels a lot better build quality wise than the 360!!!
lordrobs said:
Pressure sensitive triangle,square,circle and X buttons.
yet it has pressure sensitive triggers(how often will you need a pressure sensitive triangle button anyway), controll of the pressure sensitive buttons on the ps pads will never be good anyway as theres only like 2 mm difference between all the different sensitivities
i gotta admit i had my doubt with the first xbox pads as they were like bricks but the s pads really are a step up from any other pad i have used
360 pad is my favourite of all the controllers on all the consoles, very comfortable and obviously high quality as are all original controllers... except the N64 ones that is. Worst things ever made and was solely the reason for me not finishing Zelda: Ocarina of time, just got so frustrated with it :( What was with the analogue stick always going slack on them aswell?
I have to admit that i prefer the position of the right stick on the PS2/3 contrller to where it is on *** 360, other than that i far prefer the 360 controller.
I use it a lot when playing games like GT4.. you dont noice you are using it too well until you watch the replays with the bars for each button...
I love the ps controller myself.. always have always will.. its just perfect in design for me.. can use it for hours and never have any problems...
each to their own tho..
Joebob said:
difficult to put my finger on it but the 360 controller feels awkward to me. If there was a PS style controller out for the 360 I would buy one tomorrow.
It is simply a case of being used to what you are used to.
It is like driving a new car, takes a while to get used to it.
Play more 360, problem solved.
Mr Latte said:
Joebob Here You Go
Think its your best option and will work with PS2 controllers.
Also allows mouse and keyboard support
Look out for reviews....
Videos also on You Tube
I think I will probably just stick to the 360 controller for now, thanks anyway. I can't go back to having wires everywhere in my wirefree lounge.
