ps3 controller problem
12 May 2004
England
one of my controllers has a problem was fine other day.
ps button will not turn ps3 on I have to use the reset button on controller, once connected the ps button still doesn't work and have to turn off manually or with other controller.
I have connected via the cable and it still won't do anything when i press the ps button.
Any advice?
Got another controller you can try? Or any way to try that controller on another PS3? Shouldn't be too much of a problem with them being Bluetooth, unless you don't know anybody else with a PS3. :(
other controller is fine, just my original sixaxis one only works if I stick a pin in the reset button on controller to turn it on but the PS button still don't work.
You ever opened a ps3 controller? It's a little more complex than older type controllers. If some component has blown or gone then I'm doubtful you will be able to repair it.
Open it up and see.
