I’m new to pc building, and I’m looking to buy a mobo and a psu. The psu connection is 20+4 pin, but the mobo is just 24 pin. Is this compatible?
Yes, you just won't be using the +4, it’s an addition for different configurations.
Also, will there be a loose messy cable as I don’t include the +4?
I think mattyfez misread somewhere along the line, looking at your motherboard you have a 24 way connector so connect both the 20 and the 4 to make 24Also, will there be a loose messy cable as I don’t include the +4?
Yeah, maybe getting confused with motherboards that have an optional 4 pin.I think mattyfez misread somewhere along the line, looking at your motherboard you have a 24 way connector so connect both the 20 and the 4 to make 24![]()
To clarify OP: ALL 24 pins will be plugged in, there are no spare cables/pins.Also, will there be a loose messy cable as I don’t include the +4?
This PSU and motherboard are compatible. Brave man to buy a Gigabyte PSU, but anyhow.Ok thanks- the motherboard is the asrock b760 pro rs ddr4 atx, (has no ocuk link so I didn’t include), and also without a ocuk link, the psu it the Gigabyte P750GM 750W Modular 80 Plus Gold PSU
I don't think i would plug any cables into that PSU. (jump to 17.00 in the video)Brave man to buy a Gigabyte PSU, but anyhow.
Oh ok thxI think mattyfez misread somewhere along the line, looking at your motherboard you have a 24 way connector so connect both the 20 and the 4 to make 24![]()
Oh come on I’m terrified nowI don't think i would plug any cables into that PSU. (jump to 17.00 in the video)
So is my pc gonna blow up lol
They were running it at 140% load and it failed safely... They then ran it again and it popped.Oh come on I’m terrified now
Oh okThey were running it at 140% load and it failed safely... They then ran it again and it popped.
Not good but they were torturing it.
Sorry about scaring you, but it is something to be aware of.Oh come on I’m terrified now
Gigabyte claims that the old and new OPP thresholds are suitable for everyday usage. Nonetheless, the company is willing to offer owners a replacement with the new OPP limits. GP-P850GM with the serial number between SN20343G031011 to SN20513G022635 and GP-P750GM with the serial number from SN20243G001301 to SN20453G025430 are eligible for the exchange.
