- 10 Sep 2006
- UK
I wouldn't use a high end GPU with it, but should be fine otherwise.
Also considering I’m only using a 7700xt and an i5 12400f so the load isn’t too heavyThanks guys- I returned it am a now deciding what psu to get. I’m on a budget, so is the gigabyte ud-750gm any good? I’ve heard it’s not explosive and good for the price, and I’ve also heard good things about the Corsair rm750e, except it can be a bit noisy. any other recommendations under £90?
I have three options- what should I go forAlso considering I’m only using a 7700xt and an i5 12400f so the load isn’t too heavy
I've used a few Corsair PSUs over the years and never had any issues. That would be my choice of the three.I have three options- what should I go for
MSI Mag A750GL Gold psu
Corsair rm750e
Gigabyte UD-750GM
Any other opinions?Ok thanks![]()
It's not bad for the price but Corsair rmx has a better warranty for an extra £10 so if you can stretch go for the rmxIs this a better quality psu than the options I listed?
