Ok began a build
case is antec 902
psu = corsair 650.
If i put the corsair psu in so that the writing reads the correct way , then the fan is pointing at the bottom of the case (very bad for airflow i imagine), however i can see a small recess that i presume it may draw a small amount of air through, failing that should i be mounting it the other way round so that the writing reads upside down and the fan faces upwards.
case is antec 902
psu = corsair 650.
, You cant be using much over 300watts on that surely.
