Pump Help
17 Jun 2005
Near Brighton
So in Dec 08 i bought Swiftech Laing D5 Vario MCP655 12V DC Pump (according to ocuk order history)
Here is a picture of my actual pump:
Now, i asked a few months back if this pump (from the description) would go with one of these. I was told it would be fine.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-061-XS&groupid=962&catid=1551&subcat=
I cant work out how my pump even fits in one of those. I can only see 4 screws which hold the base on as far as i can tell. So i can only assume i was sent the wrong pump and this doesnt fit?
Can anyone confirm / deny this?
Yes you can adjust the speed from the back, you can remove the plastic around the dial to reveal a circuit board. I cant physically see any screw to remove.
I think ive bought the wrong res actually, i bought "XSPC Single DDC Dual 5.25in Bay Reservoir with Multi Fascia
looks like the one i have is for other pumps :s
Can't even return it as i bought it few months back, but ran out of money. Ah well to the mm i go.
